[Help] QT PY SAMD21 ADC Interrupt Configuration
by aconbere on Fri Mar 05, 2021 2:30 pm
I've been learning to program the SAMD21 via the qt-py. While I've had no problem getting the ADC running and checking it synchronously, when I tried to enable interrupts my interrupt handler isn't being called.
You can find my minimal test case here. My assumption is that "I'm doing it wrong". But my timer interrupt handler works great and after reading and rereading the datasheet I'm at a loss.
Hoping someone here could point out where I've gone wrong. Thanks!
Helpful Quick Links:
aconbere
Re: [Help] QT PY SAMD21 ADC Interrupt Configuration
by mckenney on Fri Mar 12, 2021 10:35 pm
  ADC->INTENSET.bit.RESRDY == 1;
Typo Alert: I expect you meant:
  ADC->INTENSET.bit.RESRDY = 1;
mckenney
