Rpi zero WH problems
by scudmonger on Sat Mar 06, 2021 3:29 pm
I received the RPI zero WH in the order
Order Confirmation No: 2500727-8503889902
However I cannot enable the Bluetooth or wifi. I have tried three different distros including the main one. Regardless of what I do there is no Bluetooth or Wifi option available.
I have tried to set the localization options however this comes back with no device configurable.
I also tried to see if it needed an update by attaching a wireless device via USB, and sudo apt-get update & upgrade, and that ran, but did not fix the wifi nor Bluetooth situation.
The project I am working on for this Pi needs wifi and Bluetooth. I have worked with Raspberry Pi’s for years and never saw this problem.
Please advise, thank you
scudmonger
Re: Rpi zero WH problems
by oliviasmithh900 on Sun Mar 07, 2021 6:24 pm
You must be doing something wrong, go over it again & again and you will get the problem.
Have you tested I/O pins of your modules, are they working fine ???
oliviasmithh900
by scudmonger on Sun Mar 07, 2021 9:14 pm
The problem is the bluetooth and wifi, the other systems work fine.
scudmonger
by adafruit_support_carter on Mon Mar 08, 2021 7:48 pm
Just to be sure - is it actually a Pi Zero W?
by scudmonger on Mon Mar 08, 2021 10:59 pm
adafruit_support_carter wrote:Just to be sure - is it actually a Pi Zero W?
Yep, per the back of it,
Raspberry Pi Zero W v1.1
scudmonger
by adafruit_support_carter on Tue Mar 09, 2021 11:15 am
Thanks. How are you currently accessing the Pi? Like with an attached keyboard/monitor? Or USB serial cable? etc.
by scudmonger on Tue Mar 09, 2021 8:57 pm
adafruit_support_carter wrote:Thanks. How are you currently accessing the Pi? Like with an attached keyboard/monitor? Or USB serial cable? etc.
I have a keyboard mouse dongle hooked up via USB cable. The keyboard and mouse work fine. Also the Pi Zero W is hooked to the monitor via HDMI and works well too.
Please note, I can hook up a wifi via USB hub, and that appears and works. I did that and updated the OS, and nothing fixed. The firmware and OS are updated.
scudmonger
by adafruit_support_carter on Wed Mar 10, 2021 1:40 pm
Let's see if there is anything useful in the kernel log. Try booting the Pi, logging in, and then running this command:
dmesg | head -20
and post the output here.
by scudmonger on Wed Mar 10, 2021 4:35 pm
adafruit_support_carter wrote:Let's see if there is anything useful in the kernel log. Try booting the Pi, logging in, and then running this command:
dmesg | head -20
dmesg | head -20
pi@raspberrypi:~ $ dmesg | head -20
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.4.83+ (dom@buildbot) (gcc version 8.4.0 (Ubuntu/Linaro 8.4.0-3ubuntu1)) #1379 Mon Dec 14 13:06:05 GMT 2020
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi Model B Rev 2
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] Reserved memory: created CMA memory pool at 0x17c00000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] On node 0 totalpages: 114688
[ 0.000000] Normal zone: 1008 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 114688 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 113680
[ 0.000000] Kernel command line: coherent_pool=1M snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 console=ttyAMA0,115200 console=tty1 root=PARTUUID=02771f68-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 376184K/458752K available (7816K kernel code, 712K rwdata, 2468K rodata, 508K init, 804K bss, 17032K reserved, 65536K cma-reserved)
pi@raspberrypi:~ $
scudmonger
by adafruit_support_carter on Wed Mar 10, 2021 4:49 pm
Thanks, that helps. That Pi has a bit of an identity crisis. Let's replace it. Send an email to support@adafruit.com with a link to this thread and your order number and they can send you a replacement Pi Zero WH.
