problem with Adalogger and Lora
by Ober on Wed Mar 10, 2021 3:32 am
Dear Adafruit,
I have a problem with using both "Adafruit Adalogger FeatherWing" (https://learn.adafruit.com/adafruit-ada ... eatherwing) and "Adafruit Feather M0 Radio with LoRa Radio Module" (https://learn.adafruit.com/adafruit-fea ... dio-module).
There is no problem with getting the RTC working, but I am unable to write data on SD card on Adalogger.
I was trying SD examples, and everytime I'm getting info 'initialization failed'.
What I know so far:
- Since I have few Adaloggers and few Adafruit Feathers M0, so it is not a problem with particular piece.
- I stacked Adalogger with "Adafruit Feather M0 WiFi - ATSAMD21 + ATWINC1500" (https://www.adafruit.com/product/3010) and everything worked fine.
- I formatted and tried many different SD cards - all of them were ok, no problem when I was using 'Adafruit Feather M0 WiFi'.
- Since I'm working with examples and they are ok with 'Adafruit Feather M0 WiFi' - it's not a problem with the code.
- I tried stacked and connected by cables. It was working with WiFi but not with Lora.
- Checked ten times - there is no problem with cables and soldering.
- I didn't found such issue on forums.
So, what should I do, how can I store data on Adalogger stacked with LoRa Radio Module?
Best Regards,
- Przemyslaw Oberbek
Ober
Re: problem with Adalogger and Lora
by adafruit_support_carter on Wed Mar 10, 2021 3:28 pm
Are you making sure to take care of the chip select pins for each of the items sharing the SPI bus? If you are running a standalone logger example, it probably does not have anything to disable the radio.
by Ober on Thu Mar 11, 2021 7:38 am
I obviously forgot to switch off the radio, so my code get lines in a void setup():
pinMode(8, OUTPUT);
digitalWrite(8, HIGH);
Thank you very much for an answer!
Best Regards,
- Przemyslaw
Ober
