Adafruit Atwinc1500 wifi module breakout
by Johnlee86 on Sat May 01, 2021 7:06 pm
#include <SPI.h>
#include <Adafruit_WINC1500.h>
#include <Adafruit_WiFiMDNSResponder.h>
// Define the WINC1500 board connections below.
// If you're following the Adafruit WINC1500 board
// guide you don't need to modify these:
#define WINC_CS   8
#define WINC_IRQ  7
#define WINC_RST  4
#define WINC_EN   2     // or, tie EN to VCC and comment this out
// The SPI pins of the WINC1500 (SCK, MOSI, MISO) should be
// connected to the hardware SPI port of the Arduino.
// On an Uno or compatible these are SCK = #13, MISO = #12, MOSI = #11.
// On an Arduino Zero use the 6-pin ICSP header, see:
//   https://www.arduino.cc/en/Reference/SPI
// Setup the WINC1500 connection with the pins above and the default hardware SPI.
Adafruit_WINC1500 WiFi(WINC_CS, WINC_IRQ, WINC_RST);
// Or just use hardware SPI (SCK/MOSI/MISO) and defaults, SS -> #10, INT -> #7, RST -> #5, EN -> 3-5V
//Adafruit_WINC1500 WiFi;
char ssid[] = "REMOVED_SSID";      // your network SSID (name)
char pass[] = "REMOVED_PW";   // your network password
int keyIndex = 0;                 // your network key Index number (needed only for WEP)
char mdnsName[] = "winc1500"; // the MDNS name that the board will respond to
// Note that the actual MDNS name will have '.local' after
// the name above, so "winc1500" will be accessible on
// the MDNS name "winc1500.local".
int status = WL_IDLE_STATUS;
// Create a MDNS responder to listen and respond to MDNS name requests.
Adafruit_WiFiMDNSResponder mdnsResponder;
Adafruit_WINC1500Server server(80);
#ifdef WINC_EN
  pinMode(WINC_EN, OUTPUT);
  digitalWrite(WINC_EN, HIGH);
#endif
  //Initialize serial and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // check for the presence of the shield:
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println("WiFi shield not present");
    // don't continue:
    while (true);
  // attempt to connect to Wifi network:
  while ( status != WL_CONNECTED) {
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    delay(10000);
  // you're connected now, so print out the status:
  printWifiStatus();
  server.begin();
  // Setup the MDNS responder to listen to the configured name.
  // NOTE: You _must_ call this _after_ connecting to the WiFi network and
  // being assigned an IP address.
  if (!mdnsResponder.begin(mdnsName)) {
    Serial.println("Failed to start MDNS responder!");
    while(1);
  Serial.print("Server listening at http://");
  Serial.print(mdnsName);
  Serial.println(".local/");
  // Call the update() function on the MDNS responder every loop iteration to
  // make sure it can detect and respond to name requests.
  mdnsResponder.poll();
  // listen for incoming clients
  Adafruit_WINC1500Client client = server.available();
  if (client) {
    Serial.println("new client");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println("HTTP/1.1 200 OK");
          client.println("Content-Type: text/html");
          client.println("Connection: close");  // the connection will be closed after completion of the response
          client.println("Refresh: 5");  // refresh the page automatically every 5 sec
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<html>");
          // output the value of each analog input pin
          for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
            int sensorReading = analogRead(analogChannel);
            client.print("analog input ");
            client.print(analogChannel);
            client.print(" is ");
            client.print(sensorReading);
            client.println("<br />");
          client.println("</html>");
          break;
        if (c == '\n') {
          // you're starting a new line
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println("client disconnected");
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your WiFi shield's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
Last edited by adafruit_support_carter on Mon May 03, 2021 1:45 pm, edited 2 times in total.
Reason: added [code] tags
Johnlee86
Re: Adafruit Atwinc1500 wifi module breakout
by adafruit_support_carter on Mon May 03, 2021 1:49 pm
Hello. Is the issue here that it is not able to connect to the WiFi network even though it can be seen in a scan?
