Problems with feather EPS32 and feather friend
by juliecorlin on Wed May 05, 2021 7:56 am
Hi Adafruit,
We are currently working with a feather ESP32 and a Feather Friend connected to a Flexible Display 2,9. All the electronics are original Adafruit components.
We are having problems finding example code where EPS32 and Feather Friend are used together. All the example codes we can find are using SPI pins. Do you have some example code where these two are used together, as the ESP32 and the friend are compatible with each other?
I have attached a picture of the setup and links to the products.
https://www.adafruit.com/product/4262
https://www.adafruit.com/product/4446
https://www.adafruit.com/product/3405
Thank you in advance.
Kind regards,
Julie
juliecorlin
Re: Problems with feather EPS32 and feather friend
by mikeysklar on Thu May 06, 2021 3:13 pm
Hi Julie,
Have you tried running the EPD_Test example?
https://github.com/adafruit/Adafruit_EP ... r/examples
You will need to uncomment the 2.9" display line for your flexible unit.
The ESP32 Huzzah is compatible with the Feather Friend just more finicky. All communication will be over SPI.
mikeysklar
