Adafruit 2MB sound board not triggering sound
by Alfiejlee on Mon May 10, 2021 2:13 pm
I recently went to use my 2MB sound trigger board I plugged it into my computer and I heard a beep I then uploaded my sound file in the correct ogg format and then gave it the correct name (T02.OGG) relevant to the pin I wanted to use. I then soldered my wires on and connected the board to a 5v power bank the green light then came on however when I shorted my wire connected to pin 2 to the ground pin the red light did not come on and no sound was produced I’ve tried everything to different ways of powering it to different speakers , different wire , resoldering the wires onto the boards and trying different pins , I have also tried WAV files and changing the name of the files and my OGG sound file plays fine through my computer reading it off the adafruit board. Do you have any suggestions as to what I've done wrong.
Alfiejlee
Re: Adafruit 2MB sound board not triggering sound
by adafruit_support_mike on Mon May 10, 2021 11:15 pm
by Alfiejlee on Tue May 11, 2021 6:23 pm
Here you go
compressjpeg.zip
(716.8 KiB) Downloaded 2 times
Alfiejlee
by adafruit_support_mike on Tue May 11, 2021 10:14 pm
Is the FX Board still connected to the computer through the USB cable?
The VS1000 won't play sounds while it still has a USB connection to the computer.
by Alfiejlee on Wed May 12, 2021 2:16 am
No the sound board is not connected to the computer in this photo it was connected to a 5v power supply
Alfiejlee
by adafruit_support_mike on Wed May 12, 2021 5:26 pm
Thank you. What voltages do you see on the trigger pins? Those can give us information about problems inside the chip.
by Alfiejlee on Wed May 12, 2021 5:30 pm
Is this the voltage between the trigger pins and the ground
Alfiejlee
by adafruit_support_mike on Wed May 12, 2021 5:34 pm
Yes.
by Alfiejlee on Thu May 13, 2021 4:37 pm
Here’s my results from testing the voltage from each pin
Pins 0-7 = 3.3v
Pin 8 = 1.2v
Pins 9-10 = 3.3v
Alfiejlee
by adafruit_support_mike on Thu May 13, 2021 10:18 pm
Alfiejlee wrote:Pin 8 = 1.2v
Bingo.. that's a hardware failure. Thank you.
Send a note containing a link to this page and your order number to support@adafruit.com. The folks there will get you a replacement FX Board.
by Alfiejlee on Fri May 14, 2021 4:47 pm
Wow you’re a genius thank you so much
Alfiejlee
