Hi, I purchased a UPS board. As you can see from the attached image there is an on/off toggle switch. i will be putting this kit inside a case and i want to let my customer move this switch. But it is quite small/fiddly. Would you know of any extension I could use please?
Adapter Swicth
- dommy123
Adapter Swicth
- Attachments
- Image if UPS with switch
- ww.jpg (251.49 KiB) Viewed 257 times
- blnkjns
Re: Adapter Swicth
Any two-way rocker switch or momentary push button will work if you don't mind soldering 2 wires to the pads after removing the current switch.
https://www.adafruit.com/product/916
https://www.adafruit.com/product/3221
- dommy123
Re: Adapter Swicth
Hi
Yes, thanks for your suggestion. I already have those switches but I did not want the switch to be that big. I was hoping to find some sort of 'sleeve' to place on top of the existing one and with the same type of dimensions as the original but just taller.
thanks again for your reply.
- Franklin97355
Re: Adapter Swicth
This might help https://www.adafruit.com/product/3870
