Getting Gravity from ICM-20948
by magicseth on Mon Jun 07, 2021 10:55 pm
I'm working on a project using the ICM-20948 9-DoF sensor.
Is there a library that I can use to get the gravity vector easily? or the motion component with gravity removed?
-s
magicseth
Re: Getting Gravity from ICM-20948
by adafruit_support_mike on Tue Jun 08, 2021 7:57 pm
The device doesn’t calculate gravity for you, but you can get a good approximation by taking a running derivative of the acceleration vector.
Store a copy of the accelerometer values before taking a new reading, then subtract the old values from the new ones. Any difference between them represents a change in acceleration, which has to be the result of an external force.. the three differences are components of a vector proportional to the change in external force. A difference of zero (or near zero) indicates constant acceleration, which comes from two things: a constant external force, and gravity.
External forces have to stop eventually, and tend to drop off quickly for most kinds of motion. A running sum of the differences should be zero most of the time.
If you subtract the running sum from each new reading, you’ll get the gravity vector.
Running sums of digital readings tend to accumulate error over time, so you’ll want to get rid of any long-term nonzero values. An easy way to do that is to multiply the running sum by 0.95 each time you calculate a new value. Any constant offsets will fade to nothing in a reasonable time. You do lose some real information too, so you can adjust the multiplier value for the best compromise. Any value between 0 and 1 will work, with small multipliers dropping to zero quickly but losing a lot of real information, and larger numbers keeping most of the real information but letting errors hang around longer.
by magicseth on Tue Jun 08, 2021 11:47 pm
Thanks, as always, for a prompt informative response! This all sounds good.
I suppose I would pre-transform the acceleration values by any change in orientation before adding to my existing acceleration values.
I'm (foolheartedly) trying to build a dead reckoning system that works for a few seconds at a time, over a very small distance.
Thanks,
Seth
magicseth
by adafruit_support_mike on Wed Jun 09, 2021 8:15 pm
Yeah, a complete system will also need to handle rotation.
Averaging can handle rotation as long as the change is relatively small from one reading to the next. The gyro readings become more important as the rotation gets faster or the sampling rate gets slower. That's where quaternions become useful.. they make it easier to describe and compare rotations.
You might also want to keep track of the magnetic vector.. that should also stay constant relative to any motion of the board. The gravity vector and magnetic vector define a plane, and you can take their cross product to get a vector perpendicular to that plane.
by sj_remington on Wed Jun 09, 2021 11:06 pm
The gravity vector can be easily derived from the quaternion, but that depends on how the quaternion is defined with respect to the sensor coordinate system.
If you are using the standard Madgwick or Mahony filter, the reference orientation is sensor X North, Y West and Z up, although how "sensor X" etc. is defined is up to the person who wrote the library and interfaced the Madgwick or Mahony filter code.
Within the Madwick or Mahony filter code, the normalized gravity reference vector Up, in the sensor frame of reference, is given by
  // Estimated direction of Up reference vector
  ux = 2.0f * (q2q4 - q1q3);
  uy = 2.0f * (q1q2 + q3q4);
  uz = q1q1 - q2q2 - q3q3 + q4q4;
Keep in mind that gravity points Up in accelerometer coordinates (along positive Z if X and Y are horizontal).
Useful reference: https://en.wikipedia.org/wiki/Quaternio ... l_rotation
sj_remington
by sj_remington on Thu Jun 10, 2021 1:46 pm
Demo for the ICM-20948, using the Mahony filter, posted at https://github.com/jremington/ICM_20948 ... ahony_AHRS
sj_remington
by magicseth on Wed Jun 16, 2021 10:38 pm
Thanks for the great pointers!
I ended up plugging in this library: https://github.com/UT2UH/Arduino_ICM209 ... l-Function
Which enables the onboard DMP which calculates linear acceleartion, gravity, and an orientation quaternion.
The quat9 orientation spins for a bit to calibrate, but stabilizes after about 30 seconds if you put it in various orientations.
The values seem pretty good.
Sometimes the values are amazing!!! Super accurate
https://imgur.com/a/NN1CgpG
Sometimes I end up with some bias leading to speed increasing in one direction.
If I multiply the speed by .9 each time, that ends up never being a problem, but then you get the problem that when you slow down, your dead reckoning algorithm thinks that's reverse motion instead of just deccelerting to 0.
Thanks for all the help with the conceptual underpinnings, now comes the hard work of trying to tune it!
-s
magicseth
by sj_remington on Wed Jun 16, 2021 10:51 pm
Thanks for posting the library link and the video. I've heard that the background sensor calibration in the DMP has been improved and would like to understand what they did. Will experiment with it!
sj_remington
