"programmer is not responding" when uploading to Flora
by eclipse19 on Tue Jun 08, 2021 12:46 am
I recently completed a design with an Adafruit Flora, NeoPixel, TCS34725 Color Sensor, and VS1053 Codec MIDI board but cannot get the code to upload to the Flora. This is a duplicate of a circuit I've built before, so I know the code and circuit is fine, but when I try to upload I'm getting a persistent error related to "avrdude: butterfly_recv()."
I'm on a Windows 10 machine and the Flora has a solid green light and a constant flashing red light. The yellow light blinks on for a second when it's trying to upload. I've confirmed that my USB cable is indeed a data cable. I've got both the correct serial port and the right board chosen (see photo). I have read through a bunch of similar threads for this problem, but none of them seem to have an answer. Can someone please help me?
Below is a copy of the output during the step that's throwing the errors:
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.49.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : avr109
         Overriding Baud Rate          : 57600
         AVR Part                      : ATmega32U4
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : butterfly
         Description     : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
Found programmer: Id = "F"; type = @
    Software Version = �.t; Hardware Version = �.
avrdude: error: buffered memory access not supported. Maybe it isn't
a butterfly/AVR109 but a AVR910 device?
         this check.
avrdude: error: programmer did not respond to command: leave prog mode
avrdude: error: programmer did not respond to command: exit bootloader
avrdude done.  Thank you.
the selected serial port
 does not exist or your board is not connected
eclipse19
Re: "programmer is not responding" when uploading to Flora
by dastels on Tue Jun 08, 2021 9:12 am
The usual first thing to try is manually resetting the Flora (i.e. press the reset button) while avrdude is trying to "sync" with the board.
dastels
by eclipse19 on Tue Jun 08, 2021 3:16 pm
I've tried doing this, but when I hit the reset button, the Flora disconnects from computer entirely, and I have to unplug the USB and plug it back in to get it to see the COM port again.
eclipse19
by dastels on Tue Jun 08, 2021 3:36 pm
That seems odd. I'd expect it to re-enumerate when it came back.
Please email support@adafruit.com with a link to this thread, your order number, and request the replacement of one Flora.
dastels
by eclipse19 on Wed Jun 09, 2021 12:07 am
Will do. Thank you so much!
eclipse19
