Adafruit SAMD51
The_Oracle_22
Adafruit SAMD51
Post by The_Oracle_22 »
This is a technical question.
Within my team
(at school) we came across the Feather M4 Can Express.
https://www.adafruit.com/product/4759.
We looked around and found your open
source schematics, thanks!
We have to explain the circuit among some other things but I wanted to know why you use a Inductor
on the VDDCORE pin and is it necessary? Looking at the datasheet, there are several ways
of making the chip run, by why 10uH? In addition, what other specifications
are there to the inductor, like resistance. Would it be possible for you to
provide me with the datasheet or similar please?
adafruit_support_mike
Re: Adafruit SAMD51
See section 54.10.1.1 in the datasheet: page 1794:
https://cdn-learn.adafruit.com/assets/a ... 01507F.pdf
The_Oracle_22
Re: Adafruit SAMD51
Okie! Thank you. In addition, if I were to replicate the circuit on my own project, would I use the switching mode like that or ignore it. I want to follow the pinouts and everything (literally to the schematic level) but would I need it. I can't find anything on Mouser like that. Could you provide me with a link to the one that you use, if that is possible?
Re: Adafruit SAMD51
If you want to duplicate the circuit, then yes.. use the switching regulator option. I can't cite specific parts of the bootloader, but the setup code probably configures the system to use it. See section 19 of the datasheet, which talks about the SAMD51's power supply controller.
The_Oracle_22
Re: Adafruit SAMD51
Ah. Thanks.
Return to “Microcontrollers”
