When using the 5V pin on the QTPy as a voltage input, what is the actual voltage min/max that can be used? Or, in other words, what are the min/max input voltages for the onboard 3v regulator and are there any other components directly connected to the 5v pin that have to be taken into account?
-K
QTPy Input voltage?
- dastels
Re: QTPy Input voltage?
2.5v to 6v
You might want to put a protection diode on it to protect your power source in case you accidently plug in USB with it connected. See https://learn.adafruit.com/assets/95390 to see the protection diode on the USB 5v line.
- professor k
Thanks for the info Dave.dastels wrote: 2.5v to 6v
Diode is already in the design as per the note in the QTPy info page, but good advice. :)
-K
