I'm trying to figure out why can't I upload a program to a Feather nRF52840 Express from a MacBook pro.
I've updated the bootloader to the latest version, here is the INFO_UF2.TXT file:
UF2 Bootloader 0.6.0 lib/nrfx (v2.0.0) lib/tinyusb (0.10.1-41-gdf0cda2d) lib/uf2 (remotes/origin/configupdate-9-gadbb8c7)
Model: Adafruit Feather nRF52840 Express
Board-ID: nRF52840-Feather-revD
SoftDevice: S140 version 6.1.1
Date: Jun 19 2021
Sketch uses 61436 bytes (7%) of program storage space. Maximum is 815104 bytes.
Global variables use 7624 bytes (3%) of dynamic memory, leaving 229944 bytes for local variables. Maximum is 237568 bytes.
Forcing reset using 1200bps open/close on port /dev/cu.usbmodem14501
PORTS {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.MALS, /dev/cu.Pampas-CSRGAIA-1, /dev/cu.S10-SerialPort, /dev/cu.SOC, /dev/cu.usbmodem14501, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.MALS, /dev/tty.Pampas-CSRGAIA-1, /dev/tty.S10-SerialPort, /dev/tty.SOC, /dev/tty.usbmodem14501, } / {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.MALS, /dev/cu.Pampas-CSRGAIA-1, /dev/cu.S10-SerialPort, /dev/cu.SOC, /dev/cu.usbmodem14501, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.MALS, /dev/tty.Pampas-CSRGAIA-1, /dev/tty.S10-SerialPort, /dev/tty.SOC, /dev/tty.usbmodem14501, } => {}
Uploading using selected port: /dev/cu.usbmodem14501
/Users/yoavluft/Library/Arduino15/packages/adafruit/hardware/nrf52/0.24.0/tools/adafruit-nrfutil/macos/adafruit-nrfutil --verbose dfu serial -pkg /var/folders/4_/5ky411vs1518t095dfg4hl3w0000gn/T/arduino_build_207540/Hardware_Test.ino.zip -p /dev/cu.usbmodem14501 -b 115200 --singlebank
Upgrading target on /dev/cu.usbmodem14501 with DFU package /private/var/folders/4_/5ky411vs1518t095dfg4hl3w0000gn/T/arduino_build_207540/Hardware_Test.ino.zip. Flow control is disabled, Single bank, Touch disabled
Opened serial port /dev/cu.usbmodem14501
Starting DFU upgrade of type 4, SoftDevice size: 0, bootloader size: 0, application size: 61444
Sending DFU start packet
Sending DFU init packet
Sending firmware file
Activating new firmware
Device programmed.
DFU upgrade took 4.419163942337036s
I've installed the SiLabs UART driver and restarted my device, but I still get the same result.
Unfortunately for me I don't have another computer to test with at the moment. I have a linux box at home so I might check it with that but it'll be really grand if there's some solution that would allow me to use my laptop.
Thanks in advance!
Yoav
