I'm using a sleep function to reduce the power consumption of a Feather m0 nrf69 operating as a remote sensor and encountered an "interesting" consequence. On entry to my loop() routine I immediately put the Feather to sleep for 10 minutes. After it wakes back up, it reads the sensors and transmits the data to my base station receiver (another Feather). This works OK, except when I want to upload a new program. The reason: when the Feather goes to sleep, the USB port disconnects -- so the Feather becomes inaccessible, except for a brief time when it reads the sensors and transmits the result.
Fortunately, the Feather's bootloader was written so that two quick presses on the reset button put it into its upload mode. This is something to consider when using an Arduino or clone that doesn't have that feature or its equivalent. If you have one without the feature, it would be wise to reserve a digital pin that can be monitored via code to prevent the microcontroller from going to sleep.
Mark
Sleep functions, something to keep in mind
- MarkEmK
Re: Sleep functions, something to keep in mind
The examples in the Arduino_Low_Power library do mention the upload issue when using the sleep routines. I didn't notice that warning when I first looked at the examples.....or it didn't penetrate my thick skull....
- Franklin97355
Thanks for posting. I'm sure others have missed that info also.
