Refurbishing Adafruit boards?
For Adafruit customers who seek help with microcontrollers
DrCyanide
Post by DrCyanide »
(I emailed support, and they recommended I try posting on the forums instead)
I ordered the Macropad (https://www.adafruit.com/product/5128), and my young daughters loved the bright neopixels and how they changed colors under the keys. I thought they were being careful enough with it, but it looks like the USB-C connector broke from the board/cable moving around a lot. In hindsight, the thicker USB-C cable I was using is less flexible and probably put extra strain on the connector. Oh well, it's the growing pains of fostering a love of tech at a young age.
The connector isn't sheered off, but it wiggles up and down, and I think the data/power pins in the back broke. There were a few times where I could hold the connector in just the right spot to power up the board, but it's not a usable solution.
I don't have the tools to replace the USB-C connector myself, but I don't want to just throw it away, since everything else on the board seemed perfectly fine while I was tinkering with it. Is there any way to refurbish the board? Even if I don't get this exact board back, it'd be a shame to send an otherwise perfect board to the landfill. I've had it for less than a week, so (other than the obvious issue) it's in perfect condition.
Re: Refurbishing Adafruit boards?
We are not set up for that type of rework. But it should be repairable in a few minutes by anyone with the right equipment. You might check with a local maker/hacker-space to see if anyone there would be willing to fix it for you.
Return to “Microcontrollers”
