Am confused with pin translation between https://www.esphome-devices.com/devices ... with-ESP32 and Huzzah32.
GPIO5-Chip Select to Huzzah Pin 11?
GPIO18-CLK Pin to Huzzah Pin ??
GPIO19-MISO Pin to Huzzah Pin 13?
GPIO23-MOSI Pin to Huzzah Pin 12?
Any help appreciated!
HUZZAH32 and CircuitSetup Split Single Phase Energy Meter Pi
- DDomnick
Re: HUZZAH32 and CircuitSetup Split Single Phase Energy Mete
If you mean the Huzzah32 breakout, its pinout lives here:
https://learn.adafruit.com/huzzah32-esp ... -3028149-8
Pin 5 is SCK
Pin 18 is MOSI
Pin 19 is MISO
and you can connect CS to any pin. Just make sure your code has the correct number for whatever pin you choose.
Pin 5 is SCK
Pin 18 is MOSI
Pin 19 is MISO
- DDomnick
No, Sorry for omitting that, was not aware of two product by that name, I have the HUZZAH32 ESP32 Feather.
I am looking at https://learn.adafruit.com/adafruit-huz ... er/pinouts
SCK appears to be pin 11 on the HUZZAH32 Feather and is ESP32 GPIO5? Not GPIO18?
MISO appears to be pin 13 on the HUZZAH32 Feather and is ESP32 GPIO19?
MOSI appears to be pin 12 and is ESP32 GPIO18?
I understand I can move CS to another pin, I'm trying to understand what the pin relationships are on the Feather versus other ESP32 based boards, and why the developer of the Energy meter has pre-programmed ESP32 dev boards and coding that are so different that the Feather pins. Thanks again for your help!!!
- DDomnick
Disregard @Mike. I think I have this figured out after more time studying.
SCK pin 11
MISO pin 13
MOSI pin 12
I will put CS on pin 10
SCK pin 11
MISO pin 13
MOSI pin 12
Glad to hear you've got it. Happy hacking!
