Pico Voltage
Eisotope
Pico Voltage
Post by Eisotope »
I ordered a R PI Pico and I am having a bit of a misunderstanding, I have read that the voltage of a Pico is 3.3v where as a computer outputs 5v. In order to use the Pico you must connect it to a computer and load the software onto it. Would a Pico be okay to use for a macro keyboard that is connected to a computer full time?
Thank you, I am trying to start into this world of electronics and have fun with it but it can be confusing at times!
Re: Pico Voltage
The processor itself operates at 3.3v. But the board is designed to be powered from a 5v USB port. There is an on-board voltage regulator that regulates the 5v down to 3.3v for the processor.
dastels
Re: Pico Voltage
Post by dastels »
The Pico is quite happy being connected to a computer's USB port. The 5v from USB is converted to 3.3v to power the board. Note that anything connected to the GPIO pins needs to be 3.3v logic, not 5v.
As for using it for a macro pad, that's essentially what the Adafruit MacroPad RP2040 is. It is a dedicated circuit buit around the RP2040 chip and does use a Pico, but all the end result is the same.
For a macropad using a Pico, have a look at https://learn.adafruit.com/diy-pico-mec ... cuitpython.
Eisotope
Re: Pico Voltage
Post by Eisotope »
Thank you much!
Return to “Microcontrollers”
