I am using an Arduino. I have SPI on it (or can bit-bang it). I need to convert the SPI to I2C and RS232.
I was looking at the FT232H chip (and breakout board). The datasheet is a bit confusing. I do not have USB in the final project to use USB, just for programming.
Does anyone know if the TT232H will do this? If not, can you suggest a chip that can?
SPI to I2C/RS232 (FT232H)
- dastels
Re: SPI to I2C/RS232 (FT232H)
1) Which Arduino?
2) Any board with SPI likely also has I2C and serial (i.e. Rx/Tx). Why do you need/want to convert from SPI?
3) From a quick scan of the datasheet (https://ftdichip.com/wp-content/uploads ... FT232H.pdf) it looks like all the modes are "USB to <whatever>:".
- mrbandit_stg
I'm using an ESP32-PICO-KIT.
Does not look like it has SPI and I2C.
I can bit-bang the SPI - done it before.
My "cheat" is to use a pro-mini. They are only $10 (less on Amazon).
The ESP32-PICO-KIT has three UARTS. I can use one to talk to the pro-mini.
