RTC DS3231 with NRF52840
For Adafruit customers who seek help with microcontrollers
olivier1870
Post by olivier1870 »
Good morning,
I would like to store data in the Istby memory, with timestamps. I tried to connect a DS3231 and use the Adafruit RTC library but the system crashes (i.e. compilation through Arduino IDE foes fine, but the prog does not run for some reason)
Any idea?
Many thanks
adafruit_support_carter
Re: RTC DS3231 with NRF52840
Please post a photo of your setup showing how everything is connected. What arduino sketch are you trying to run?
olivier1870
Many thanks for your quick reaction.
The setup is as follow:
Itsby NRF52840 + Oled display 1.3 (Adafruit) + pressure sensor (MS58303): connection via I2C -> all works fine
I added an RTC DS3231 (Adafruit) to I2C -> all ok.
I picked up the example here: File->Examples->RTClib->ds3231 -> rtc commands seem to be blocking the prog (e.g. DateTime now = rtc.now();)
olivier1870
Hi
0x3D = OLED display
0x76 = Pressure sensor
0x68 = RTC (DS3231)
cheers
olivier1870
Noe the example ds3231 works fine! I must have made a mistake ...
Many thanks for your help!!!
Wish you a nice day
Return to “Microcontrollers”
