Hi all,
So, I have a metro express, connected to the 9601 Thermocouple amplifier board, using a 4-wire cable soldered to it (power, gnd, clock and data). The cable is about 200mm in length.
When all is connected, I have a green power light on the 9601, telling me all is well...
I followed the 9601 example precisely and did not mess with the address... then loaded in the example code that was also specified with the 9601 example. (https://learn.adafruit.com/adafruit-mcp9601/pinouts)
When running the code, I get a message that it can't find the 9601 (here is the code that produces the "Sensor not found" error:)
/* Initialise the driver with I2C_ADDRESS and the default I2C bus. */
if (! mcp.begin(I2C_ADDRESS)) {
Serial.println("Sensor not found. Check wiring!");
while (1);
And yes, I did check the (4) wires. Obviously power works
So... this is about as simple as an I2C implementation can possibly get, right? So very discouraging.
Where does one go from here?
Thank you for all of your kind suggestions.
First I2C project - total fail
- Franklin97355
Re: First I2C project - total fail
How are you connecting the amplifier to the metro? Can you post a shot of your connection and soldering? Thanks.
- SkyRyder
Solder to the amp board:
- SkyRyder
Solder to the header:
- SkyRyder
The entire set-up:
- Franklin97355
Have you tried to scan the i2c address with a basic sketch? (found it here https://learn.adafruit.com/scanning-i2c ... i2c-basics
- SkyRyder
I rung out each wire, and found that I had nicked the clock wire, giving me high resistance or even an open...
I took care of that, problem solved!
I'm dangerous with a knife, apparently.
Thank you for your kind help.
