I will need a help with setting sensitivity scale using ICM-2048 sensor.
I am using "https://github.com/adafruit/Adafruit_Ci ... ICM20X.git" library.
Could you give me suggestion how to change sensitivity scale?
Best regards!
Sensitivity
- adafruit_support_carter
Re: Sensitivity
Take a look at accelerometer_range and gyro_range:
https://circuitpython.readthedocs.io/pr ... t/api.html
- Matr777
Re: Sensitivity
Thank you for sending the link.
Could you also suggest me if there can be added external circuit to increase the sensitivity?
Best regards!
Best regards!
Re: Sensitivity
Nothing really, since all analog sensing and conversion is done internally to the sensor.
