Display of SPI sensor data and I2C display won't work.
For Adafruit customers who seek help with microcontrollers
HerrFistus
Post by HerrFistus »
Hello. For a DIY project, I want to read out temperatures of an electric furnace and display it on a small OLED display. I use a S-type thermocouple with a MAX31856 SPI Module. As Display I bought a SH1106 I²C display. The microcontroller is a Seeeduino Xiao. I tested both components before, both work fine. I put the contents of both example codes together as follows:
#include <Adafruit_MAX31856.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SH110X.h>
#define i2c_Address 0x3c //initialize with the I2C addr 0x3C Typically eBay OLED's
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET -1   //   QT-PY / XIAO
Adafruit_SH1106G display = Adafruit_SH1106G(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
Adafruit_MAX31856 maxthermo = Adafruit_MAX31856(3);
double temp=0;
  Serial.begin(115200);
  while (!Serial) delay(10);
  Serial.println("MAX31856 thermocouple test");
  if (!maxthermo.begin()) {
    Serial.println("Could not initialize thermocouple.");
    while (1) delay(10);
  display.setTextSize(2);
  display.setTextColor(SH110X_WHITE);
  display.setCursor(0, 0);
  maxthermo.setThermocoupleType(MAX31856_TCTYPE_S);
  maxthermo.setConversionMode(MAX31856_ONESHOT_NOWAIT);
  maxthermo.triggerOneShot();
  delay(200);
  if (maxthermo.conversionComplete()) {
    temp=maxthermo.readThermocoupleTemperature();
  } else {
    Serial.println("Conversion not complete!");
  display.println(temp);
But the program seems to stop working just at the point where I want to print the reading on the display. Changing
at the end to a serial printin command works again. How can this be possible? Is this maybe a SRAM (32KB) problem?
Re: Display of SPI sensor data and I2C display won't work.
You are missing a display.begin() in your setup.
HerrFistus
Thank you, I could make the code run now:
#include <SPI.h>
#include <Wire.h>
#define LOGO16_GLCD_HEIGHT 16
#define LOGO16_GLCD_WIDTH  16
double temp;
  display.begin(i2c_Address, true);
  display.clearDisplay();
  display.setTextSize(1);
  display.println("Temp:");
  display.display();
  delay(2000);
  delay(50);
    display.display();
    delay(1000);
    } else {
    //Serial.println("Conversion not complete!");
It works fine now. Nevertheless, when I copy this part
    display.display();
    delay(1000);
out of the if/else expression, the displayed value returns zero instead of the reading. Do you know how this can happen?
If that is all that changed, I'd expect it to display zero until the first conversion was complete. After that it should display the previous value until updated by the next conversion.
Return to “Microcontrollers”
