I'm trying to build my own custom PCB based on an ATSAMD21E chip. I made a PCB breakout for the ATSAMD21E that just supports the reset button, a 3.3V voltage regulator, and a couple of capacitors.
After building the PCB with a fresh ATSAMD21E from Digikey, I connected it over a Segger JLink, and then flashed a bootloader onto the chip successfully using Microchip Studio. The bootloader I am using was Adafruit's QtPy bootloader, which uses the same chip as I am, also without an external crystal, so I thought that would work.
Unfortunately at this point I just get an error message "USB Device Not Recognized" instead of seeing a new USB device show up as expected.
Here is the schematic for my PCB:
I mostly just copied this from Adafruit's schematic for the QtPy. I followed these instructions:
https://learn.adafruit.com/how-to-progr ... ootloaders
for flashing the bootloader (which worked, I just can't see the USB port).
I have tried this with two different boards built from scratch with all separate components just in case it was a soldering problem, which did not solve the problem -- the second time the flashing of the bootloader worked fine again, and once again the USB device did not show up.
What am I doing wrong?
Building my own PCB based on QtPy schematic - USB not found
- spolsky
- danhalbert
Re: Building my own PCB based on QtPy schematic - USB not fo
You could try dumping the flash and verifying it looks like the flash on the QTPy. Also, make sure there are reasonable values for the fuses: if the fuses are set to all 1's, the board will trigger a watchdog reset every few seconds. There's a lot of discussion of fuse settings in the uf2 repo, e.g.: https://github.com/adafruit/uf2-samdx1/ ... -611128451
Other than that it's hard to say without debugging the board, making sure the design is OK, etc.
- spolsky
Thanks for that advice! At this point I think there’s something wrong with my PCB design… but I can’t be sure. I definitely noticed that Lady Ada’s PCBs use much wider traces than I did, and I think the fact that some of my prototyping is on breadboards is causing problems too. I’m going to try designing a new PCB more carefully and see if that helps!
