Hi! I want to build a triggered LED for my drums, and I found the perfect guide here on Adafruit.
The problem that its dated, and I don’t understand if I can still use Gemma for this, and if it wil work with my mac (macbook pro 2019)
One of the featured prosuct for this project is the “Metro M4”, and I dont understand if i need this or the gemma, and if i need the metro, how do I connect the wires?
Btw, I have no idea about how all this works, Im a musician who is looking for a cheap alternative to the market of Triggere LED.
The article:
https://learn.adafruit.com/gemma-powere ... tive-drums
Drum triggered LED help
- dastels
Re: Drum triggered LED help
I would avoid the Gemma V2. The code doesn't look to be Gemma V2 specific so you should be able to use pretty much any controller board. The Gemma M0 https://www.adafruit.com/product/3501 would be the most direct replacement. A Trinket M0 https://www.adafruit.com/product/3500 or QTPY https://www.adafruit.com/product/4600 should work as well.
Note that the Gemma M0 has a battery connector; there'd be a bit of work to add one to either of the other boards.
- Tzabi
Hi dastles! Thank you for the reply.dastels wrote:I would avoid the Gemma V2. The code doesn't look to be Gemma V2 specific so you should be able to use pretty much any controller board. The Gemma M0 https://www.adafruit.com/product/3501 would be the most direct replacement. A Trinket M0 https://www.adafruit.com/product/3500 or QTPY https://www.adafruit.com/product/4600 should work as well.
So if il take the Gemma, il spare the work of soldering the battery?
And one last question, how do I know where to connect the wires of this project if the scheme in the article is for Gemma v2?
- dastels
Yes, the Gemma M0 has an onboard battery connector. Just get a LiPo and plug it in. Be sure to get a LiPo with the right polarity wiring. Getting one from Adafruit is the safest option.
The connections should be the same. The Gemma M0 is meant to be a more-or-less drop in replacement for the V2.
- Tzabi
Thank you very much Dave!dastels wrote:Yes, the Gemma M0 has an onboard battery connector. Just get a LiPo and plug it in. Be sure to get a LiPo with the right polarity wiring. Getting one from Adafruit is the safest option.
I have another question if it ok :)
In the featured products of the project that I want to do, which is the LED drum triggers, there is a "Adafruit Metro M4 feat. Microchip ATSAMD51", which I don't see in the guide, or in the video, why Is that product on the featured product list?
- dastels
No idea. It's quite a different board than the Metro. And *not* usually battery powered. If going beyond the Metro type board, a Feather would be the way I go (they have onboard battery support). But the Gemma M0 is perfectly adequate and is easy to connect to. I do advise soldering if possibly, though, just to get solid, reliable connections.
