My Feather nRF52 isn't working with my new BNO055. I swapped in another nRF52 and that one works as expected. Suppose that's why I put a piece blue tape on the non-working nRF52 :) I don't think it ever worked properly.
Is there some way to troubleshoot this device and fix it? Or is there a way to get a replacement part?
Thanks,
Paul
Feather nRF52 i2c doesn't work
Re: Feather nRF52 i2c doesn't work
Do you have any other I2C devices you can use to test the nRF52?
- PaulELong
@adafruit_support_mike, I have another 8266 that when I insert it into the same circuit works fine. So, I'm pretty sure this 8266 is faulty.
Thanks, Paul
Thanks, Paul
The nRF52 and the ESP8266 are different boards.
Swapping one dev board for another is a valid test, though we usually prefer to test the same board with a different I2C device.
Which board do you have, and when did you get it?
