STEMMA Soil Sensor - I2C Capacitive Moisture Sensor and Badg
For Adafruit customers who seek help with microcontrollers
thalesfsp
Post by thalesfsp »
Any help on how to integrate both? Badger (https://shop.pimoroni.com/products/badg ... 2959852627) runs MicroPython. Thank you!
rpiloverbd
Re: STEMMA Soil Sensor - I2C Capacitive Moisture Sensor and
Post by rpiloverbd »
Can't see any straightforward method. Badger's Pins are visible at the back of the board. So, if you somehow manage to solder L-shaped female connectors with those pins, You'll be able to connect the STEMMA Soil Sensor - I2C Capacitive Moisture Sensor with the I2C pins. Then you can do the coding by using the necessary micropython libraries.
Return to “Microcontrollers”
