I’ve just got a Gemma m0 - trying to see if it could run 3x pixels of Govee RGBIC 12v strip. The little chips on the lights say ws2811.
I’ve tried (both sides of the strip - incase I’m wiring them backwards).
I’ve tried using the neopixel lib.
Thanks for any help.
Gemma m0 - Govee RGBIC strip lights? 12v
- Franklin97355
Re: Gemma m0 - Govee RGBIC strip lights? 12v
Exactly what strip did you get, how did you power them and how did you connect them? Can you post a picture of the connections?
- JohnBottle
Hi franklin97355 - thank you for your reply!
I am trying to use Govee RGBIC LED Strip Lights. 12v - model: H6127
This is a sample of the strip:
They are not sold as "home dev" or anything - they come with a controller.
I just thought it might be possible to control them with the circuitpython neopixel library.
I do not know if they are not working because either:
1) They are 12v, I have cut them down to just 3 pixels. to try and make them work with 5v
2) They are just not compatible - maybe govee have a unique non-standard way of making the lights work.
I have the GRN, Vout, and A2 pins connected to the strips
Thanks for any help!
