Hi there!
As the subject suggests, I'm hoping someone here has or knows of a controller with 2 DAC's integrated into the board.
It must be 5 volt with minimum 8 bit control.
If there is such a thing as converting 3 volt analog to 5 volt analog in a format smaller than a U.S. quarter we could maybe use that in a breakout setup,
but since the leading issues in production are related to external DACs we are trying to eliminate them as breakout boards.
Would really appreciate if anyone has a lead or can point me in the right direction.
Controller with 2 Channel DAC outputs?
- blnkjns
Re: Controller with 2 Channel DAC outputs?
The smallest I know is the Itsy Bitsy M4, but that is 3,3V. But if you see how small it is, you can probably add a dual channel opamp IC to it within your size limits. It will add like 1cm2.
