QT Py SAMD21 - core frequency
For Adafruit customers who seek help with microcontrollers
tomhavel
Post by tomhavel »
I have been recently playing with the QT PY SAMD21 and I have one question. While using the Arduino IDE, is there any way to change the core clock frequency? If I am not mistaken and my measurements are correct, it does not run on 48MHz out of the box. Thank you!
mikeysklar
Re: QT Py SAMD21 - core frequency
Post by mikeysklar »
I've not seen a way to do it through Arduino, but forcetronics has a github repo and 20+ minute video explaining how to do it with C++.
https://blog.adafruit.com/2021/01/06/ow ... cetronics/
westfw
Post by westfw »
What makes you think that it's not running at 48MHz?
The Arduino Build commands show:
Compiling sketch...
/Applications/Arduino-1.8.13.app/Contents/Java/portable/packages/adafruit/tools/arm-none-eabi-gcc/9-2019q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -Wall -Wextra -Wno-expansion-to-defined -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD "-D__SKETCH_NAME__=\"\"\"SAMD_Explorer.ino\"\"\"" -DF_CPU=48000000L -DARDUINO=10813...
adafruit2
Post by adafruit2 »
if you're trying to speed it up, just FYI the SAMD21 does *not* do overclocking well
tomhavel
Post by tomhavel »
Thank you for your replies. My measurements must have been wrong. However, I'll have one more question (I hope it can relate to this)
I have been testing the speeds of the native USB port. I used very simple code:
unsigned long timee;
  Serial.begin(1000);
  timee=micros();
  Serial.write('C');
  Serial.println(micros()-timee);
The results are however quite surprising with one byte transfer taking as long as 50 microseconds. Is this normal or am I missing something major?
Thank you
mikeysklar
Please open a new forum thread with the USB serial question. It is unrelated to the topic and will be helpful for others if properly labeled. Also include full code so we can see your serial baudrate settings.
Return to “Microcontrollers”
