led controle with pca9685
djhieronymus
Post by djhieronymus »
I have a raspberry pi zero w with pca9685 board contect.
On the pca board will only be connect led.
I can control the led's but not individual.
Exaple if channel 0 is on and i also want channel 2 on.
Then channel 0 is going off.
is there a script or can some help me out to fix this
mikeysklar
Re: led controle with pca9685
Post by mikeysklar »
Can you post a photo of how you have connected the LEDs and the code you are using to drive them? Are you using setPWM()?
djhieronymus
led are connected true the yellow and black pin off the pca9685
#!/usr/bin/python
import Adafruit_PCA9685
pwm2 = Adafruit_PCA9685.PCA9685(address=0x41)
pwm2.set_pwm_freq(1000)
pwm2.set_pwm(x, 4096, 0);
i also done this the same for channel 2 , 3 ....
mikeysklar
Are you missing some lines of code? The example code has an i2c initialization.
import board
import busio
import adafruit_pca9685
pca = adafruit_pca9685.PCA9685(i2c)
https://learn.adafruit.com/16-channel-p ... 2998544-10
The full code for dimming LEDs looks like:
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
# This simple test outputs a 50% duty cycle PWM single on the 0th channel. Connect an LED and
# resistor in series to the pin to visualize duty cycle changes and its impact on brightness.
from board import SCL, SDA
import busio
# Import the PCA9685 module.
from adafruit_pca9685 import PCA9685
# Create the I2C bus interface.
i2c_bus = busio.I2C(SCL, SDA)
# Create a simple PCA9685 class instance.
pca = PCA9685(i2c_bus)
# Set the PWM frequency to 60hz.
pca.frequency = 60
# Set the PWM duty cycle for channel zero to 50%. duty_cycle is 16 bits to match other PWM objects
# but the PCA9685 will only actually give 12 bits of resolution.
pca.channels[0].duty_cycle = 0x7FFF
https://learn.adafruit.com/16-channel-p ... 2998655-26
djhieronymus
when i use fullscript , i get this error:
File "/usr/local/lib/python3.7/dist-packages/adafruit_bus_device/i2c_device.py", line 174, in __probe_for_device
self.i2c.writeto(self.device_address, b"")
File "/usr/local/lib/python3.7/dist-packages/busio.py", line 169, in writeto
return self._i2c.writeto(address, buffer, stop=stop)
File "/usr/local/lib/python3.7/dist-packages/adafruit_blinka/microcontroller/generic_linux/i2c.py", line 52, in writeto
self._i2c_bus.write_bytes(address, buffer[start:end])
File "/usr/local/lib/python3.7/dist-packages/Adafruit_PureIO/smbus.py", line 314, in write_bytes
self._device.write(buf)
OSError: [Errno 121] Remote I/O error
During handling of the above exception, another exception occurred:
File "/usr/local/lib/python3.7/dist-packages/adafruit_bus_device/i2c_device.py", line 180, in __probe_for_device
self.i2c.readfrom_into(self.device_address, result)
File "/usr/local/lib/python3.7/dist-packages/busio.py", line 159, in readfrom_into
return self._i2c.readfrom_into(address, buffer, stop=stop)
File "/usr/local/lib/python3.7/dist-packages/adafruit_blinka/microcontroller/generic_linux/i2c.py", line 59, in readfrom_into
readin = self._i2c_bus.read_bytes(address, end - start)
File "/usr/local/lib/python3.7/dist-packages/Adafruit_PureIO/smbus.py", line 181, in read_bytes
return self._device.read(number)
File "test.py", line 17, in <module>
File "/usr/local/lib/python3.7/dist-packages/adafruit_pca9685.py", line 141, in __init__
self.i2c_device = i2c_device.I2CDevice(i2c_bus, address)
File "/usr/local/lib/python3.7/dist-packages/adafruit_bus_device/i2c_device.py", line 61, in __init__
self.__probe_for_device()
File "/usr/local/lib/python3.7/dist-packages/adafruit_bus_device/i2c_device.py", line 183, in __probe_for_device
raise ValueError("No I2C device at address: 0x%x" % self.device_address)
ValueError: No I2C device at address: 0x40
djhieronymus
have fixed my selves , first led is working
mikeysklar
What was the resolution to your issue?
djhieronymus
first i had board error
clean install sd with raspberry pi lite to start
then follow the instructions off:
https://learn.adafruit.com/circuitpytho ... -test-3-15
after that install driver off pca9685
Return to “Microcontrollers”
