As far as I can tell the board is defective. After following the simple procedures to set up the Arduino IDE for this board, and to run the basic "Blink" code, the compilations proceeds properly, but end with a fatal error, as indicated below.
I would appreciate your help confirming the problem and debugging or replacing the board as needed.
Thank you
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/mscohen/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/mscohen/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/mscohen/Documents/Arduino/libraries -fqbn=esp32:esp32:adafruit_qtpy_esp32_pico:PartitionScheme=default,UploadSpeed=921600,PSRAM=enabled,DebugLevel=none -vid-pid=1A86_55D4 -ide-version=10813 -build-path /var/folders/05/7fv7q7q91214b_lk8l9k8cz80000gn/T/arduino_build_9833 -warnings=none -build-cache /var/folders/05/7fv7q7q91214b_lk8l9k8cz80000gn/T/arduino_cache_634400 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=/Users/mscohen/Library/Arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=/Users/mscohen/Library/Arduino15/packages/esp32/tools/xtensa-esp32s3-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=/Users/mscohen/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=/Users/mscohen/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.esptool_py.path=/Users/mscohen/Library/Arduino15/packages/esp32/tools/esptool_py/3.3.0 -prefs=runtime.tools.esptool_py-3.3.0.path=/Users/mscohen/Library/Arduino15/packages/esp32/tools/esptool_py/3.3.0 -prefs=runtime.tools.mkspiffs.path=/Users/mscohen/Library/Arduino15/packages/esp32/tools/mkspiffs/0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=/Users/mscohen/Library/Arduino15/packages/esp32/tools/mkspiffs/0.2.3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=/Users/mscohen/Library/Arduino15/packages/esp32/tools/xtensa-esp32s2-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=/Users/mscohen/Library/Arduino15/packages/esp32/tools/xtensa-esp32s2-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.mklittlefs.path=/Users/mscohen/Library/Arduino15/packages/esp32/tools/mklittlefs/3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=/Users/mscohen/Library/Arduino15/packages/esp32/tools/mklittlefs/3.0.0-gnu12-dc7f933 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=/Users/mscohen/Library/Arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.riscv32-esp-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=/Users/mscohen/Library/Arduino15/packages/esp32/tools/riscv32-esp-elf-gcc/gcc8_4_0-esp-2021r2-patch3 -verbose /Users/mscohen/Documents/Arduino/sketch_aug03a/sketch_aug03a.ino ....
... esptool.py v3.3
Creating esp32 image...
Merged 2 ELF sections
Successfully created esp32 image.
python3 /Users/mscohen/Library/Arduino15/packages/esp32/hardware/esp32/2.0.4/tools/gen_esp32part.py -q /var/folders/05/7fv7q7q91214b_lk8l9k8cz80000gn/T/arduino_build_9833/partitions.csv /var/folders/05/7fv7q7q91214b_lk8l9k8cz80000gn/T/arduino_build_9833/sketch_aug03a.ino.partitions.bin
Using library Adafruit_NeoPixel at version 1.10.5 in folder: /Users/mscohen/Documents/Arduino/libraries/Adafruit_NeoPixel
/Users/mscohen/Library/Arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32-elf-size -A /var/folders/05/7fv7q7q91214b_lk8l9k8cz80000gn/T/arduino_build_9833/sketch_aug03a.ino.elf
Sketch uses 268269 bytes (20%) of program storage space. Maximum is 1310720 bytes.
Global variables use 16608 bytes (5%) of dynamic memory, leaving 311072 bytes for local variables. Maximum is 327680 bytes.
esptool.py v3.3
Serial port /dev/cu.usbmodem54790143151
Connecting....
Chip is ESP32-PICO-V3-02 (revision 3)
Features: WiFi, BT, Dual Core, 240MHz, Embedded Flash, Embedded PSRAM, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: ac:0b:fb:69:4c:c8
Uploading stub...
A fatal error occurred: Failed to write to target RAM (result was 01070000: Operation timed out)
