Moving servo to 50 degree
by prayag2010 on Thu Oct 27, 2011 12:27 pm
I am building a project for my car in which a character LCD (http://www.adafruit.com/products/181) will display the current temperature of the car using LM35 temp. sensor and we can set the current temperature and a servo will control the speed of the AC in the car (using an arduino) but for that, I need to get the servo to 50 degrees and I seem to have a problem in that. The servo is not moving a bit. I tried using 2 different servos (HXT900 and Futaba S3003) but to no avail. Here is the code that I tried to move the servo to 50 degree :-
#include <Servo.h>
Servo myservo; // create servo object to control a servo
void setup()
myservo.attach(9); // attaches the servo on pin 9 to the servo object
void loop()
int i = map(i, 0, 1023, 0, 179); // scale it to use it with the servo (value between 0 and 180)
i = i+50; // moves the servo to 50 degree
myservo.write(i); // sets the servo position according to the scaled value
delay(15); // waits for the servo to get there
I haven't bought the LCD yet but I plan to set the same or a similar one soon.
It will be a great help if you will help a newbie like me....
prayag2010
Re: Moving servo to 50 degree
by adafruit_support_bill on Thu Oct 27, 2011 1:01 pm
'i' is never initialized before you call 'map'. Assuming it is initialized by default to zero (although assuming is seldom wise), the result of the map call will always be zero.
by prayag2010 on Thu Oct 27, 2011 1:49 pm
So how should I write the code ? I can't seem to get it since I am a newbie......
prayag2010
by adafruit_support_bill on Thu Oct 27, 2011 2:05 pm
To move the servo to 50 degrees is simply:
myservo.write(50);
If you want it to be proportional to the temperature, you need to read your temperature sensor first. See this tutorial:http://www.ladyada.net/learn/sensors/tmp36.html
