🎁📬❄️📦 Holiday Shipping Deadlines are approaching! International customers and domestic ground - get your orders in 12/9/2020 📦❄️📬🎁
dt006 6pin
dt006 6pin
by GhostWolf on Sat Jan 26, 2008 7:24 am
I have built a dt006 programmer or at least tried. For some reason it doesn't work. here is the diagram I used:
What did I do wrong?
edit:
The photo is for illustrating purposes and is not of my boarduino.
original photo (c) ladyada
GhostWolf
by mtbf0 on Sat Jan 26, 2008 7:58 am
that's a parallel port programmer, right?
how are you powering the board? looks like you're jumpered for usb.
mtbf0
by GhostWolf on Sat Jan 26, 2008 8:23 am
well, I'm powering it from the external. and it is a parallel port programmer.
(ps. My boarduino have a three pin jumper so the rs232-ttl port is powering my max232 chip in my RS232 programming cable.)
GhostWolf
by mtbf0 on Mon Jan 28, 2008 12:18 am
i was just looking at the schematic for the minipov2 which has a dt006 style programmer built onto the board and notice that there is no resistor on the reset line. there is a pullup, but that's not between the parallel port and the avr. the resistor values are different, but the minipov runs on 3v and the boarduino runs on 5v. also pins 19-21 on the parallel connector are connected to ground, not 18-20.
mtbf0
