programming x0x atmega from serial port
by gzifcak on Wed Jan 30, 2008 10:48 pm
hi,
the usb in my x0xb0x is apparently not working, so i was wondering about upgrading the firmware from a serial port.
does anyone know if it would be possible with one of these:
http://microcontrollershop.com/product_ ... ts_id=1820
and this program:
http://www.lancos.com/prog.html
if so, would i need to have it in bootload mode? or do i just turn on the x0xb0x and hook it up, then use ponyprog to send it the hexfile?
thanks in advance for any suggestions,
greg
gzifcak
by Entropy on Thu Jan 31, 2008 8:46 am
I'm not entirely familiar with the x0x, but I do recall it has an AVR in it, and I'm fairly certain it has an ICSP header. (Not sure if it's 10-pin or 6-pin).
That serial programmer should work if there is an ICSP header, but Ladyada's USBTinyISP is more "future proof" since it doesn't rely on a (rapidly disappearing) RS-232 serial port. (Many USB-to-serial converters will not work for AVR programming.)
Entropy
by gzifcak on Thu Jan 31, 2008 12:19 pm
great! thanks for the info. would i need to have the x0x in its "bootload" mode or would it work just powered up in any state (that's my impression)?
gzifcak
by adafruit on Thu Jan 31, 2008 3:15 pm
theres no ICSP on the x0xb0x....wish i had put one on :(
by Entropy on Thu Jan 31, 2008 5:31 pm
Entropy
by gzifcak on Fri Feb 01, 2008 4:30 am
wait a sec, if i understand correctly, all this means is that i have to solder the wires from the serial port programmer to the applicable pins of the x0x microcontroller, no? i could care less about an actual pin socket, if that's what this is about.
gzifcak
