Difference between analog and PWM
by magician13134 on Sat Feb 02, 2008 9:33 pm
What's the difference between analog and PWM? Isn't the analogOut() on the arduino the same as PWM? But is that the same as the PWM example I saw for the MiniPOV? Because I made a neat RGB mixer on the Arduino and I'd like to transfer it to work with a 2313 and no Arduino. It requires three pins that I could fade and one that would read a pot. Is this possible? Thanks
magician13134
by adafruit on Sat Feb 02, 2008 10:25 pm
for almost all microcontrollers, PWM == analog output
however, PWM is not == analog input
which is a bit confusing
by magician13134 on Sat Feb 02, 2008 10:30 pm
So I can't use a pot with the attiny2313? At all? Ever? Any other equal sized/priced/simple chips that I can? Will the product sheet say "Analog input on pins 4, 5, 6"?
magician13134
by adafruit on Sun Feb 03, 2008 1:57 am
yah from what i remember the attiny2313 dont got an ADC :( the attiny26 does i think.
by Entropy on Sun Feb 03, 2008 3:02 pm
Somewhere I recall seeing a description of using 1-2 digital input pins on a microcontroller combined with a little bit of external circuitry to implement a sigma-delta ADC.
I'll see if I can find a link...
Entropy
by CCarlson on Mon Feb 04, 2008 10:36 am
I'm an utter, abject newbie, so please forgive my ignorance...
The summary here says that the ATtiny2313 has 1 Analog Comparator--is this not the analog input you're looking for?
CCarlson
by Entropy on Mon Feb 04, 2008 11:49 am
A comparator only tells you whether the voltage on one input is greater or less than on another.
An ADC tells you what the voltage on a given pin is.
Entropy
by CCarlson on Mon Feb 04, 2008 1:19 pm
You know, if I'd spent even a moment thinking about it, that would have been totally apparent to me.
On the up-side, I've learned something new today. Now I'm off the hook for the rest of the day. Thanks!
CCarlson
by adafruit on Mon Feb 04, 2008 2:03 pm
Entropy wrote:Somewhere I recall seeing a description of using 1-2 digital input pins on a microcontroller combined with a little bit of external circuitry to implement a sigma-delta ADC.
IIRC, you can do that but only for measuring resistance, so good for photocells but not for like, IR distance sensors :(
by darus67 on Mon Feb 04, 2008 4:53 pm
Essentially you hang an R/C (resistance/capacitance, NOT Radio Control)
circuit out there and measure the rise time. Change the resistance and the rise time will change.
I know the Basic Stamp uses that sort of scheme to do analog input.
I disremember the exact details, unfortunately.
ladyada wrote:IIRC, you can do that but only for measuring resistance, so good for photocells but not for like, IR distance sensors :(
He wants to hook up a pot, so this should work fine.
"He's just this guy. You know?"
darus67
by Søren on Sat May 03, 2008 11:58 am
Any µ-controller can do (voltage) A/D-C.
As long as it has 2 free I/O's at least - by adding 1 resistor, 1 cap for the timing and a comparator to compare the rising (or falling if you wanna be different :)) voltage to the analog voltage in question.
Measure the time from conversion start to comparator flags and you have a count proportional to the magnitude of the analog voltage (not linear though, but that can be solved with either a table or a function, or it can be lineariced with a CCG).
Søren
cron
