Deploying AVR libc code?
by Jaanus on Sat Feb 16, 2008 3:27 am
I built myself a nice little Boarduino and am now trying to program it. Everything works perfect in the Arduino development environment when using the Arduino's own system calls (the stuff from http://www.arduino.cc/en/Reference/HomePage). I can upload code to board, run programs etc.
I would like to move on to AVR libc and deploy more low-level code, but I am having trouble figuring out how exactly the development toolchain works. As far as I understand, I can just #include the relevant avr libraries and enter the code directly in the Arduino dev. environment. However, when I enter the following code...
#include <avr/io.h>
const int ledPin = 13;                // LED connected to digital pin 13
void setup()                    // run once, when the sketch starts
  pinMode(ledPin, OUTPUT);      // sets the digital pin as output
  digitalWrite(ledPin, LOW);  // make sure it's low before going to use the
                            // libc calls
  DDB |= 0b100000;   // pinMode(13, OUTPUT)
  PORTB |= 0b100000; // digitalWrite(13,1);
void loop()                     // run over and over again
The Arduino compiler says: "error: invalid suffix "b100000" on integer constant In function 'void setup()':"
I am sure it's something simple I'd need to do... any hints? :roll:
Jaanus
by adafruit on Sat Feb 16, 2008 12:42 pm
you need a more recent compiler
by Jaanus on Sat Feb 16, 2008 1:03 pm
Hmm... I'm using Arduino 0010 which is the integrated environment and seems to be the newest ver. Should I install anything on top of that?
Jaanus
by adafruit on Sat Feb 16, 2008 1:35 pm
arduino wasnt built with a recent compilre, so dont use 0b notation and you're fine
by Jaanus on Sat Feb 16, 2008 1:47 pm
Thanks! :) I converted to hex and now I'm not getting this particular error any more.
Jaanus
by Jaanus on Sun Feb 17, 2008 5:23 pm
Maybe this helps someone else... I figured it out with external help. The code I posted has two bugs:
1) instead of 0b100000 notation, use B100000 notation
2) it should be DDRB, not DDB
and then it works :)
Jaanus
