Learning AVR assembly: tools and resources?
by A. Square on Thu Mar 20, 2008 5:26 pm
I'm interested in taking the plunge and starting to learn assembly for my AVRs. For now, I'm more interested in reading through compiled code (both from the Arduino environment and C code compiled using avrgcc) to understand what's going on, and to optimize speed; I figure that will be a nice introduction to eventually programming routines in assembly, if I ever need to.
Can anyone suggest resources for learning, and what tools I might want to use to do it? Things that can run on OS X are especially appreciated! (ladyada, I know you're an OS X user; any recommendations?)
Are there any disassemblers/decompilers that will be useful, or do I have to go through the hex line-by-line?
Jonathan
A. Square
by cell on Thu Mar 20, 2008 5:41 pm
the avr manual (and some of the app-notes) feature code snippets in both C and assembly.
cell
by cell on Thu Mar 20, 2008 5:44 pm
actually, you will probably never need to write an entire project in assembly.
what you probably want is to be able in insert inline chunks of assembly into your c code.
http://www.nongnu.org/avr-libc/user-man ... e_asm.html
cell
by darus67 on Thu Mar 20, 2008 5:47 pm
Given the right set of command line options, you can get GCC to just generate assembly code files from the C source.
That seems easier than decompiling the object or hex files.
"He's just this guy. You know?"
darus67
by A. Square on Thu Mar 20, 2008 6:35 pm
cell wrote:the avr manual (and some of the app-notes) feature code snippets in both C and assembly.
I've seen the code snippets, but I guess I'm looking for more of a command and language reference.
darus67 wrote:Given the right set of command line options, you can get GCC to just generate assembly code files from the C source.
I didn't realize GCC would do that, and that is great for projects written in straight C. However, for looking at Arduino code a disassembler might be the easiest way. This disassembler, which even has a precompiled OS X binary, looks like it might be just the ticket.
Thanks for the suggestions, and, of course, more references and tools are always appreciated.
A. Square
