🎁📬❄️📦 Holiday Shipping Deadlines are approaching! International customers and domestic ground - get your orders in 12/9/2020 📦❄️📬🎁
_delay_ms() crashing?
by mojo on Thu Mar 27, 2008 9:12 pm
I am having a problem with the following code. Whenever I insert a call to _delay_ms() or _delay_loop_2() the AVR freezes:
while(1)
      t = 1 << z;
      z++;
      if (z>7) {z=0;}
      PORTC = t && 0b00111111;
      j = 0b00010001;
      if (t && 0b01000000) {j &= 0b00000001;}
      if (t && 0b10000000) {j &= 0b00010000;}
      PORTD = j;
      for (j=0; j<200; j++)
         _delay_ms(1);
      PORTD = 0b00010001;
Is it a bug in avr-libc? My code is using the AVR-USB stuff, maybe it interferes with it.
mojo
by adafruit on Thu Mar 27, 2008 9:43 pm
i know you need to have the frequency defined somehow
maybe thats the problem
by mojo on Fri Mar 28, 2008 9:30 am
I did check and the frequency is defined... However, I am now getting some very strange results with normal code too. Here is my loop:
uint8_t   i, j, k;
for(;;)
   PORTC = displaycounter;
   displaycounter++;
   j = 100;
   while(--j)
      i = 100;
      while(--i)
         k = 100;
         while(k--);
It freezes and does not loop... I am totally stumped. Interrupts are not enabled.
mojo
by mojo on Fri Mar 28, 2008 9:40 am
I found the problem!
I looked at the assembler code for my loop, and it seems that the optimiser had optimised it to nothing. Inserting a NOP fixed it. It looks like the same thing happens with the _delay_ms() function - it's optimised into oblivion.
Worryingly, the optimisation seems to happen even if I optimise for size rather than performance :(
mojo
by adafruit on Fri Mar 28, 2008 3:01 pm
_delay_ms() shouldnt be optimized out so im surprised by that. the code should have been declared 'volatile' but then again i havent actually verified that
