Did I kill it?
Did I kill it?
by mb_ on Tue Apr 29, 2008 2:36 pm
So I've got a class that has a board w/ an ATMega128 on it, and the makefiles we've been using have 'make install' setup to download code to the board.
I'm not using this makefile at home, but I spaced out and did 'make install' instead of 'make flash' a few minutes ago.
Now avrdude doesn't see my atmega48. I just get back:
this check.
So I'm a total noob with respect to embedded development, but from what I understand my 'make install' command changed the fuses and now it's in a state where I can't use ISP to flash code onto the chip.
Can I force avrdude to undo this or did I brick the thing? (I'm using usbtinyisp btw)
mb_
by darus67 on Tue Apr 29, 2008 3:54 pm
Can you post the contents of your makefile here?
That way we can see what it did, for sure.
"He's just this guy. You know?"
darus67
by mb_ on Tue Apr 29, 2008 4:32 pm
# Name: Makefile
# Author: <insert your name here>
# Copyright: <insert your copyright message here>
# License: <insert your license reference here>
# This is a prototype Makefile. Modify it according to your needs.
# You should at least check the settings for
# DEVICE ....... The AVR device you compile for
# CLOCK ........ Target AVR clock rate in Hertz
# OBJECTS ...... The object files created from your source files. This list is
#                usually the same as the list of source files with suffix ".o".
# PROGRAMMER ... Options to avrdude which define the hardware you use for
#                uploading to the AVR and the interface where this hardware
#                is connected.
# FUSES ........ Parameters for avrdude to flash the fuses appropriately.
DEVICE     = atmega48
CLOCK      = 20000000
PROGRAMMER = -c usbtiny -P avrdoper
OBJECTS    = main.o TWI_Master.o lcd.o
FUSES      = -U hfuse:w:0xd9:m -U lfuse:w:0x24:m
# ATMega8 fuse bits (fuse bits for other devices are different!):
# Example for 8 MHz internal oscillator
# Fuse high byte:
# 0xd9 = 1 1 0 1   1 0 0 1 <-- BOOTRST (boot reset vector at 0x0000)
#        ^ ^ ^ ^   ^ ^ ^------ BOOTSZ0
#        | | | |   | +-------- BOOTSZ1
#        | | | |   +---------- EESAVE (set to 0 to preserve EEPROM over chip erase)
#        | | | +-------------- CKOPT (clock option, depends on oscillator type)
#        | | +---------------- SPIEN (if set to 1, serial programming is disabled)
#        | +------------------ WDTON (if set to 0, watchdog is always on)
#        +-------------------- RSTDISBL (if set to 0, RESET pin is disabled)
# Fuse low byte:
# 0x24 = 0 0 1 0   0 1 0 0
#        | |  |       +------- CKSEL 3..0 (8M internal RC)
#        | |  +--------------- SUT 1..0 (slowly rising power)
#        | +------------------ BODEN (if 0, brown-out detector is enabled)
#        +-------------------- BODLEVEL (if 0: 4V, if 1: 2.7V)
# Example for 12 MHz external crystal:
# Fuse high byte:
# 0xc9 = 1 1 0 0   1 0 0 1 <-- BOOTRST (boot reset vector at 0x0000)
# Fuse low byte:
# 0x9f = 1 0 0 1   1 1 1 1
#        | |  |       +------- CKSEL 3..0 (external >8M crystal)
#        | |  +--------------- SUT 1..0 (crystal osc, BOD enabled)
# Tune the lines below only if you know what you are doing:
AVRDUDE = avrdude $(PROGRAMMER) -p $(DEVICE)
COMPILE = avr-gcc -Wall -Os -DF_CPU=$(CLOCK) -mmcu=$(DEVICE)
# symbolic targets:
all:   main.hex
.c.o:
   $(COMPILE) -c $< -o $@
# How to compile a .cc file into a .o file
.cpp.o:
   $(COMPILE) -c -g $< -o $@
#   $(COMPILE) -c -g  $< -o $@
.S.o:
   $(COMPILE) -x assembler-with-cpp -c $< -o $@
# "-x assembler-with-cpp" should not be necessary since this is the default
# file type for the .S (with capital S) extension. However, upper case
# characters are not always preserved on Windows. To ensure WinAVR
# compatibility define the file type manually.
.c.s:
   $(COMPILE) -S $< -o $@
flash:   all
   $(AVRDUDE) -U flash:w:main.hex:i
fuse:
   $(AVRDUDE) $(FUSES)
# Xcode uses the Makefile targets "", "clean" and "install"
install: flash fuse
# if you use a bootloader, change the command below appropriately:
load: all
   bootloadHID main.hex
clean:
   rm -f main.hex main.elf $(OBJECTS)
# file targets:
main.elf: $(OBJECTS)
   $(COMPILE) -o main.elf $(OBJECTS)
main.hex: main.elf
   rm -f main.hex
   avr-objcopy -j .text -j .data -O ihex main.elf main.hex
# If you have an EEPROM section, you must also create a hex file for the
# EEPROM and add it to the "flash" target.
# Targets for code debugging and analysis:
disasm:   main.elf
   avr-objdump -d main.elf
cpp:
   $(COMPILE) -E main.c
The FUSE setting in the make file should probably be:
FUSES      = -U hfuse:w:0xdf:m -U lfuse:w:0xff:m
And maybe can I run:
avrdude -c usbtiny -P usb -p atmega48 -U hfuse:w:0xdf:m -U lfuse:w:0xff:m -F
mb_
by darus67 on Tue Apr 29, 2008 5:12 pm
If I'm interpreting the fuse bits correctly, I believe you have set the chip
to use an external low frequency crystal.
If your board doesn't have the appropriate crystal, the serial programmer
won't work.
The good news is that the serial programming fuse is still enabled.
Its when you disable serial programming that you're really hosed.
I used the fuse bit calculator found here: http://palmavr.sourceforge.net/cgi-bin/fc.cgi
to interpret the fuse bits.
darus67
by mb_ on Tue Apr 29, 2008 6:58 pm
Well I had a 12 MHz crystal laying around so I wired it up but I'm still unable to change the fuse... maybe I need something slower like 1MHz?
$ avrdude -c usbtiny -P usb -p atmega48 -U hfuse:w:0xdf:m -F
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x000000
avrdude: Yikes!  Invalid device signature.
avrdude: Expected signature for ATMEGA48 is 1E 92 05
avrdude: reading input file "0xdf"
avrdude: writing hfuse (1 bytes):
Writing |                                                    | 0% 0.00s ***failed;
Writing | ################################################## | 100% 0.05s
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xdf:
avrdude: load data hfuse data from input file 0xdf:
avrdude: input file 0xdf contains 1 bytes
avrdude: reading on-chip hfuse data:
Reading | ################################################## | 100% 0.00s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
         0xdf != 0x00
avrdude: verification error; content mismatch
avrdude: safemode: hfuse changed! Was df, and is now 0
Would you like this fuse to be changed back? [y/n]
mb_
by darus67 on Wed Apr 30, 2008 10:41 am
I would guess you need something slower.
The data sheet should have more info about what they mean by
"low frequency"
darus67
by mattkenny on Thu May 01, 2008 12:25 am
The low frequency crystal setting usually requires a 32.768 kHz crystal (also known as a watch crystal).
mattkenny
