Understanding Compiler Errors and Warning
by Russ Nagel on Thu May 22, 2008 10:00 am
All
I am using AVR Studio Ver 4.13 with SP 2. Can someone direct me to a source that helps explain compiler errors?
I am getting:
../Pushthebutton.c:20: error: expected expression before 'int'
Russ
Russ Nagel
by MrShifty on Thu May 22, 2008 12:43 pm
I develop on Linux, but I'll bet that ARV Studio's errors are similar to those that GCC outputs. Here are some lists, but they are by no means exhaustive:
http://www.digitalfanatics.org/index.ph ... ilerErrors
http://www.network-theory.co.uk/docs/gc ... ro_94.html
Anyway, that error looks like a syntax-related error (misplaced punctuation or whitespace). If you post a snippet of your code around the offending line, we can help you debug.
MrShifty
by Russ Nagel on Thu May 22, 2008 12:59 pm
I'll put the links you provided in my favorites. After taking a break I took a closer look and found the error. I wanted to give a parameter I was passing to a function a type (int) when I had already done that previously in the program.
Thanks for your help
Russ
Russ Nagel
