How to write a function and how to generate random numbers
by magician13134 on Sun Jun 01, 2008 8:04 am
Hi, I'm working on a project and I need to generate two, one digit random numbers and pass them to a function. I've seen examples of functions, like this one:
void
delayms (uint16_t millis)
So I know the void is the return type, and the millis is the parameter, but what kind of data type is a uint16_t? Is it just an integer?
And as for random numbers, that's pretty self explanatory as to what I need.
magician13134
by mtbf0 on Sun Jun 01, 2008 9:30 am
dude. the google is your friend. for instance for uint16_t the second result is this.
googling avr random numbers gets this as its second result. so it looks like you already have a random number generator. just be aware that unless you are able figure out a clever way to seed it, you will get the same sequence of random numbers every time you run your program. there's a reason they call these beasts pseudo random number generators.
i leave googling c function definition as an exercise, but a copy kernighan and ritchie would not be a bad thing to have.
mtbf0
by magician13134 on Sun Jun 01, 2008 9:31 am
Ah. Thanks
magician13134
by magician13134 on Sun Jun 01, 2008 5:38 pm
How do I seed rand without using a constant? I remember in C++ we seeded random with the current time... but since these microcontrollers don't know the time after a reset... What do you use to seed it? Oh, I tried "srand(get_sys_count())", but to no avail...
magician13134
by mtbf0 on Sun Jun 01, 2008 7:00 pm
magician13134 wrote: so I used
int i = rand() % 9 + 1;
int j = rand() % 9 + 1;
and j always equals 6 and i always equals 5... I've looked all over the internet, but can't seem to find a reasonable solution (yes I've included stdlib.h) Any ideas?
yes. i believe i predicted this result. a computer being a deterministic thing is going to return the same sequence of random numbers every time you start it up. so you have to figure out a way to seed the random number generator. pull a number out of thin air. something. big computers use the time. so you could start a loop. wait a while after you turn on your project, then push a button and grab a count out of the loop to seed the random number generator. or something.
assuming you have a PORTB, put a pullup on pin 1 and attach an n/o switch between pin1 and ground and this might work.
uint32_t foo;
for (foo = 0; PORTB & ~(1<< PB1); foo += 13);
srandom (foo);
did you put the define for rand max before or after you included stdlib. 'cuz it's defined in stblib.
mtbf0
by mtbf0 on Sun Jun 01, 2008 7:05 pm
spooky.
you deleted your post while i was quoting it.
or my laptop's imagining things.
mtbf0
by magician13134 on Sun Jun 01, 2008 7:12 pm
Ah, yes, I reread your post, and recalled seeding... But I think I figured it out, I'm writing a random number to EEPROM, then seeding with it, then writing a new random number for the next time. It seems to be working. Thanks for your help :D
Ahh! I'm finished with the breadboard version! I saw a neat video about a research of whether time "slowed down" in a crisis situation. They used a neat device called a perceptual chronometer, so I built a smaller version. A video of mine can be seen here, and there's a link to the original right below the video
http://www.youtube.com/watch?v=xqm1yBLHDWA
This device basically flashes a random number too quickly to read in a normal situation, and pressing the button displays the number to verify. Now I get to go to King's Island to test :D
magician13134
by darus67 on Mon Jun 02, 2008 3:24 pm
I was going to suggest saving a seed in EEPROM, but you beat me to it.
Another possibility might be to read data from a digital input pin that is left
floating.
"He's just this guy. You know?"
darus67
by magician13134 on Mon Jun 02, 2008 4:57 pm
Only problem is I don't have anymore IO pins! I've never used this many before, it's kind of exciting!
magician13134
by mtbf0 on Tue Jul 01, 2008 11:07 pm
the new issue of servo has an article about random number generators, including reading random values off of an unconnected adc pin.
mtbf0
by franklin97355 on Wed Jul 02, 2008 12:56 am
millis is the count of ms since the device was reset. It just might be random enough to be a seed.
franklin97355
