AT90S2313 and ATTiny2313 the same?
by adilumer on Mon Jun 02, 2008 11:40 pm
I want to build the minipov3 and I have AT90S2313, can I use this chip instead of ATTiny2313? Can someone please explain what's the difference and if its possible to use AT90S2313.
adilumer
by magician13134 on Tue Jun 03, 2008 12:09 am
http://www.electro-tech-online.com/micr ... y2313.html
The link on that page is a bit hard to follow, here's the document they suggested reading:
http://www.atmel.com/dyn/resources/prod ... oc4298.pdf
So I would say, yes, it may take a bit of tweaking, but probably not. If it does, we're here to help, and the MiniPOV is open-source, so you should be fine
magician13134
by adilumer on Wed Jun 11, 2008 12:09 am
magician13134 wrote:http://www.electro-tech-online.com/micro-controllers/24689-ok-at90s2313-attiny2313.html
Thanks so much, it worked like a charm!
adilumer
