Need help with 24bit addressing SPI EEPROM (25AA1024)
by mngrif on Mon Jun 23, 2008 4:02 pm
I have an EEPROM (from Microchip, several of them) that takes a 24bit address. As best I can figure out there is no variable type that is made for 24 bits, the best match is 32. So I need a way to send only the bottom 24 bits of the 32 bit int. Or another way all around...
This is on the ATmega168. The EEPROM in question is the 25AA1024. It takes data MSB first.
Any help would be most appreciated since google is failing me on this one!
mngrif
by adafruit on Mon Jun 23, 2008 11:29 pm
sounds fine to me
or 3 8 bit variables :)
by mngrif on Tue Jun 24, 2008 3:28 am
The problem with sending a 32bit int is that there is 8 extraneous bits being sent that are fouling things up (all writes go to sector 0 (until it gets in to high sectors) since the rest is considered a part of the actual data to be written).
3x8bit packets is an option that I'll explore though (might foul up timing???), but that's as ugly as perl. *MUCH* thanks for the idea though! It's what I'll use for now. Really, thanks!
I'm really looking for a custom 24bit int data type if someone has it laying around or can point me in the right direction. The search terms are just too broad for teh searchez to be of use :\
mngrif
by mtbf0 on Tue Jun 24, 2008 8:22 am
what you need is some casting, some shifting and some masking. all of these are covered with distressing lack of detail in the arduino reference or in any c or c++ book. i'm still recommending kernighan and ritchie.
 uint32_t memaddr;
unit8_t msb = (uint8_t)(memaddr >> 16);        // most significant bits
uint8_t osb = (uint8_t)((memaddr >> 8) & 0xff);// some other significant bits
uint8_t lsb = (uint8_t)(memaddr & 0xff);       // least significant bits
mtbf0
Re: Need help with 24bit addressing SPI EEPROM (25AA1024)
by ioniser on Sun Oct 16, 2011 7:58 pm
did you end up geting this to work? I am also having trouble using a 328p arduino with the 25AA1024
cant seem to get the coms working at all. tried a couple librarys, also wrote my own and still no luck.
ioniser
Re:
by cstratton on Sun Oct 16, 2011 11:18 pm
mngrif wrote:The problem with sending a 32bit int is that there is 8 extraneous bits being sent that are fouling things up (all writes go to sector 0 (until it gets in to high sectors) since the rest is considered a part of the actual data to be written).
The address is usually preceded by a command byte - can you just make that bits 31-24 of your value? So for example, on the chip I'm playing with at the moment, using my debug tool, if I type
03 00 00 00 it starts reading from address 0
03 01 00 00 it starts reading the second 64KB
03 02 00 00 etc
Where "03" is the read command on my particular part.
But in my firmware, I'm dealing with the SPI one byte at a time, so I don't really have your problem. If I were dealing with it in 16 bit words, I could still solve it this way be combining the command and the high byte of the address into the high word, and then the lower two bytes in the low word.
That said, my chip does at times insist on getting only 8 clocks - try to give it a write enable command with a dummy byte following, and it won't accept it.
cstratton
by ToBeFrank on Tue Oct 18, 2011 4:11 pm
This is how I do it when I want to handle a standard type in a byte oriented way:
typedef union
  uint32_t value;
  uint8_t bytes[sizeof(uint32_t)];
} some_type_t;
You'd then access the 32 bit like this:
some_type_t var;
var.value = 0x12345678;
uint32_t val32 = var.value;
And you'd access the individual bytes like this:
uint8_t byte0 = var.bytes[0];
uint8_t byte1 = var.bytes[1];
uint8_t byte2 = var.bytes[2];
uint8_t byte3 = var.bytes[3];
ToBeFrank
