same error over and over, :file not found, help if possible
by twillie2002 on Thu Sep 18, 2008 6:39 pm
I'm new to this but the 1st time I tried to program the ATTiny 45 chip it worked fine, now it allways gives me this error even using different hex files. I have it in my C:\windows, I have googled the problem but have had no luck, Any help please!
C:\Documents and Settings\twillie>avrdude -c usbtiny -p t45 -U flash:w:test_leds.hex
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e9206
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "test_leds.hex"
avrdude: error opening test_leds.hex: No such file or directory
avrdude: input file test_leds.hex auto detected as invalid format
avrdude: can't open input file test_leds.hex: No such file or directory
avrdude: write to file 'test_leds.hex' failed
avrdude: safemode: Fuses OK
avrdude done. Thank you.
Thomas J Williams
twillie2002
by adafruit on Fri Sep 19, 2008 4:42 pm
the programmer is fine as it is talking to the chip
the programming software cant find "test_leds.hex"
that is not a programmer problem, that is a missing file problem
by twillie2002 on Fri Sep 19, 2008 5:42 pm
I have the file in my windows directory, I don't understand in the command line where the path statement is that tells it where to look for the file, So I can check it or change it, In "dos" there was a line like: "c:\windows" telling where the file was. THANKS for the reply
Thomas J Williams
twillie2002
by mtbf0 on Fri Sep 19, 2008 8:45 pm
pretty sure it will be looking for C:\Documents and Settings\twillie\test_leds.hex
if it's in c:\windows use the cd command to change your working directory
cd C:\windows
or it may be that
avrdude -c usbtiny -p t45 -U flash:w:c:\windows\test_leds.hex
would work, but that silly colon in the windows device specification might throw things off.
i'd suggest trying to escape the colon, but i've no idea what character to use in windows. where i come from we use \ but i just can't see that working.
mtbf0
by twillie2002 on Fri Sep 19, 2008 10:39 pm
Thanks! that worked, Can you tell me what in the origanal line is telling it to look in C:windows? just to help me understand. Again thanks I have it working now!!
Thomas J Williams
twillie2002
by mtbf0 on Fri Sep 19, 2008 10:58 pm
assuming it was the cd command that did the trick, cd is a command to change your current working directory. by default your working directory is revealed in the windows commend line prompt, so the directory you were originally in was C:\Documents and Settings\twillie. here's what a piece of a windows command line session might look like when you issue a cd command...
C:\Documents and Settings\twillie>cd c:\windows
C:\Windows>cd
before issuing the cd command avrdude will attempt to find the file in C:\Documents and Settings\twillie and afterwards it will look in C:\Windows. if you want to return to your login directory just type cd with no arguments.
mtbf0
by twillie2002 on Sat Sep 20, 2008 1:13 am
Thanks I understand now , Thats why it worked before, it was already at c:windows and I was looking in the AVRDUDE command for info on file location. Back to the basics lesson for me!
Thomas J Williams
twillie2002
