Newbie help needed...
by Watson on Sun Sep 28, 2008 3:12 pm
I'm trying to run a Attiny2313 with this test program:
#include <avr/io.h> // this contains all the IO port definitions
int main(void) {
DDRB = 0xFF; // set all 8 pins on port B to outputs
PORTB = 0xFF; // set all the pins on port B high (turn on those LEDs)
while (1); // basically halt, do nothing forever
I get an Ok message from avrdude (like this http://www.ladyada.net/images/avrtutori ... exprog.jpg) when burning the chip with this program's HEX, but the chip refuses to work! I connected some LEDs to PORTB same way MINIPOV3 does (http://www.ladyada.net/images/minipov3/minipov3schem.png) and there is no LED activity... help :(
Watson
by mtbf0 on Sun Sep 28, 2008 3:28 pm
in the absence of the actual output from avrdude and a picture of the circuit i'd guess led polarity.
mtbf0
by oPossum on Sun Sep 28, 2008 3:40 pm
Make sure the AVR's configuration fuses are set correctly.
oPossum
by Watson on Sun Sep 28, 2008 3:59 pm
mtbf0,
the output is almost exactly like this one http://www.ladyada.net/images/avrtutori ... exprog.jpg except that i'm burning all_leds.hex and not test_leds.hex. The LED's polarity have been triple checked.
oPossum,
I read about fuses here http://www.ladyada.net/learn/avr/fuses.html but I thought that AVRDUDE would take care of them itself. How do I burn them onto the chip?
Watson
by Watson on Sun Sep 28, 2008 4:02 pm
Oh - I read again about programming here http://www.ladyada.net/learn/avr/avrdude.html and it says "...or hfuse, lfuse or efuse for the chip configuration fuses, but we aren't going to mess with those" - I guess this scared me a little :) i'll experiment with this.... (the -U option)
Watson
by Watson on Sun Sep 28, 2008 4:15 pm
Bummer, the fuse calculator suggested here http://www.ladyada.net/learn/avr/fuses.html - which is http://sourceforge.net/projects/palmavr/ - is for Palm OS...
Watson
by Watson on Sun Sep 28, 2008 4:42 pm
Ok, using this one http://www.vonnieda.org/AVRFuses/ (there are Mac & Windows versions)
What are the values of the fuses to be used with lets say - MiniPOV3? Or, where can I find them? I mean, the schematics and the firmware are provided, what about the fuses? where should a newbie look? AND, reading about fuses in the tutorial (http://www.ladyada.net/learn/avr/fuses.html), I don't find any "critical" looking fuse to be set... the default values looks ok to me.. :roll:
Anyway, I've used these:
- Preserve EEPROM
- SPI enabled
- BOD = 4.3V
- Int. RC Osc. 8MHz, 14 CK + 65 ms
Burning the fuses was a success but still no signs of life from the chip...
Watson
by macegr on Sun Sep 28, 2008 5:57 pm
Are you sure your LED resistor values are correct? 47 ohms, not 47 kohms or something?
macegr
by mtbf0 on Sun Sep 28, 2008 6:55 pm
dumped the fuses on my brain machine.
/home/user> avrdude -c dasa -p t2313 -P /dev/ttyUSB0 -v
avrdude: Version 5.5, compiled on Feb  9 2008 at 04:38:00
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         System wide configuration file is "/usr/local/etc/avrdude.conf"
         User configuration file is "/home/user/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port            : /dev/ttyUSB0
         Using Programmer      : dasa
         AVR Part              : ATtiny2313
         Chip Erase delay      : 9000 us
         PAGEL                 : PD4
         BS2                   : PD6
         RESET disposition     : possible i/o
         RETRY pulse           : SCK
         serial program mode   : yes
         parallel program mode : yes
         Timeout               : 200
         StabDelay             : 100
         CmdexeDelay           : 25
         SyncLoops             : 32
         ByteDelay             : 0
         PollIndex             : 3
         PollValue             : 0x53
         Memory Detail         :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65     6     4    0 no        128    4      0  4000  4500 0xff 0xff
           flash         65     6    32    0 yes      2048   32     64  4500  4500 0xff 0xff
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          2    0      0     0     0 0x00 0x00
         Programmer Type : SERBB
         Description     : serial port banging, reset=rts sck=dtr mosi=txd miso=cts
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.31s
avrdude: Device signature = 0x1e910a
avrdude: safemode: lfuse reads as E4
avrdude: safemode: hfuse reads as DF
avrdude: safemode: efuse reads as FF
avrdude: safemode: Fuses OK
avrdude done.  Thank you.
/home/user>
to burn these settings run this command
avrdude -c dasa -p t2313 -P /dev/ttyUSB0 -U lfuse:w:0xE4:m -U hfuse:w:0xDF:m
of course, you'll have to supply a port name in place of "/dev/ttyUSB0" that is appropriate for your os.
mtbf0
by magician13134 on Sun Sep 28, 2008 7:11 pm
Ummm, this may be stupid, but can you say this:
while (1);
Doesn't it need to be
while (1){}
magician13134
by mtbf0 on Sun Sep 28, 2008 7:18 pm
magician13134 wrote:Ummm, this may be stupid, but can you say this:
while (1);
yes.
magician13134 wrote:Doesn't it need to be
while (1){}
not necessarily.
mtbf0
by The_Don125 on Sun Sep 28, 2008 7:37 pm
Is it possible the compiler is noticing nothing in the while loop, and simply removing it? Maybe try:
int main(void)
     while (1) // loop forever
          PORTB = 0xF0; // set half the pins on port B high, and the other half low
The_Don125
by oPossum on Sun Sep 28, 2008 9:01 pm
// Tell the compiler that 'a' can be changed by something outside
// the loop so it will not optimize away any loop that tests 'a'
volatile int a=1;
while(a);
oPossum
by Watson on Mon Sep 29, 2008 4:31 am
I assume that Ladyada's test_leds program has been used before "as is"... :)
Anyway, I also used this code (from alt_leds.c):
#include <util/delay.h>
// This function basically wastes time
void delay_ms( uint16_t milliseconds)
   for( ; milliseconds > 0; milliseconds--)
      _delay_ms( 1);
int main(void) {
  PORTB = 0x0;       // set all pins on port B low (turn off LEDs)
  while (1) {
    PORTB = 0xAA;      // turn on LEDs #2,4,6,8
    delay_ms(500);    // delay half a second
    PORTB = 0x55;      // turn on LEDs #1,3,5,7
No visible chip activity.
Mtbf0, I tried using that fuse values you supplied (mine were: LOW=0xe4, HIGH=0xd9, EXTENDED=0xff). Still nothing.
Watson
by Watson on Mon Sep 29, 2008 4:43 am
ISSUE RESOLVED GA~!@#IT!
(almost:)
The moment I unplugged the serial cable it started working. Why is that, electronically?
Checking, I see the serial cable's pin7 takes the AVR's pin 1 (^reset) low...
BTW: Is there a way to enable the circuit AND having it connected to the serial? This way I could make use it to control stuff by computer via serial AND update it's firmware in a "press of a button"! :twisted:
Watson
