Microcontroller
For Adafruit customers who seek help with microcontrollers
Franklin97355
Re: Microcontroller
Post by Franklin97355 »
Are you checking for resistance? (Ohms)
sk854016
Re: Microcontroller
Post by sk854016 »
Yeah I checked for that
Franklin97355
Re: Microcontroller
And what did you get when you measured between COM and NO when the relay was activated and when it wasn't?
sk854016
Re: Microcontroller
Post by sk854016 »
When the relay is not active it read a 1 , when it is active it read a 0
Franklin97355
Re: Microcontroller
Then it is working.
sk854016
Re: Microcontroller
Post by sk854016 »
Why does no voltage appear when the relay is active
Franklin97355
Re: Microcontroller
It is a switch and connects COM to the NO pin when activated nothing more. Check out how a relay works
sk854016
Re: Microcontroller
Post by sk854016 »
I understand that, what I am saying is that I have a positive and negative power supply running to the DC+ and DC- ports. The NC NO and COM ports do not have any reading in regards to any voltage at all. They have ohm readings but the voltage is not reaching the output ports.
Franklin97355
Re: Microcontroller
It is not supposed to. Please read the manual for your thermostat so you will understand what should be happening.
sk854016
Re: Microcontroller
Post by sk854016 »
Shouldn't I be getting a reading of 12v from the Com and NC port when the relay is not activated?
Screen Shot 2016-01-11 at 11.24.55 AM.png (144.62 KiB) Viewed 476 times
sk854016
Re: Microcontroller
Post by sk854016 »
I think I understand now, I would connect my 12v power source to the DC+ and DC- ports. Also I would run a wire from my DC + port to my COM port so when the relay is active it connects to the NO port.
sk854016
Re: Microcontroller
Post by sk854016 »
So, my virginmobile phone sim card doesn't work with the sim900 shield for the arduino. I was suggested to use a Ting sim card through Aadfruit. This would work well with a sim900 shield? What would be the cost per sms?
Franklin97355
Re: Microcontroller
Which shield are you interested in?
sk854016
Re: Microcontroller
Post by sk854016 »
Return to “Microcontrollers”
