Retrieve MCP9808 temperature value with Huzzah ESP8266 ?
by Khoi on Mon Oct 05, 2015 10:23 am
Hi All,
I want to log the temperature of my vaccine fridge (I'm a French pharmacist) into a database stored on my NAS webserver.
1) I succeeded to read the temperature from MCP9808 with an Arduino UNO board.
2) I succeeded to read the temperature from MCP9808 with the Huzzah ESP8266 board with Lua scripts (in this case, I have the value without decimals).
3) Then I tried to do the same with Arduino IDE and it failed (error exception). I think the SDA / SCL pins are not the same than an Arduino UNO.
Is there an "easy" solution with Arduino IDE ?
Is it possible to define other SDA/SCL Gpio pins ?
I take a look at the SoftI2C library but don't understand how to use it.
Best regards,
Khôi.
Khoi
Re: Retrieve MCP9808 temperature value with Huzzah ESP8266 ?
by Khoi on Mon Oct 05, 2015 1:16 pm
Here is the code :
#include <Wire.h>
#include "Adafruit_MCP9808.h"
Adafruit_MCP9808 tempsensor = Adafruit_MCP9808();
  Serial.begin(115200);
  Serial.println("Huzzah ESP8266 - MCP9808");
  if(!tempsensor.begin()) {
    Serial.println("Couldn't find MCP9808!");
    while(1);
  float c = tempsensor.readTempC();
  Serial.print("Temp: "); Serial.print(c); Serial.print("*C\t");
  delay(250);
Serial monitor
ctx: cont
sp: 3ffe9bb0 end: 3ffe9d80 offset: 01b0
>>>stack>>>
3ffe9d60: 00000000 00000000 3ffe9da4 40201cbf
3ffe9d70: 00000000 00000000 3ffe8d60 40100118
<<<stack<<<
ets Jan 8 2013,rst cause:2, boot mode:(1,7)
ets Jan 8 2013,rst cause:4, boot mode:(1,7)
wdt reset
Khoi
by bbx10node on Mon Oct 05, 2015 8:53 pm
Try SCL connected to pin #5 and SDA connected to pin #4. If it does not work swap them around.
See the following for more details.
https://github.com/esp8266/Arduino/blob ... digital-io
bbx10node
by Khoi on Tue Oct 06, 2015 1:53 am
Thanks a lot!
It's working !
Khoi
by morwic on Fri Dec 28, 2018 1:02 am
So what would the config look like to send data to adaio with a esp8266 ?
Thank You
morwic
