DC Brushed Motor Not Running Correctly
- odonohoe
Re: DC Brushed Motor Not Running Correctly
Dear Support , thank you for the information. I am using a circuit constructed on a breadboard with a transister and a diode. Do you think that this is okay for driving a DC motor in one direction with a 9 volt battery? thanks
- odonohoe
#include <Servo.h>
Servo esc;
int arm = 1000
int speedvalue;
int steady = 300
int initiate = 0
// put your setup code here, to run once:
esc.attach(6);
esc.writeMicroseconds(arm);
delay(2000);
esc.writeMicroseconds(1200);
delay(15);
esc.writeMicroseconds(1300);
delay(15);
void loop()
// put your main code here, to run repeatedly:
if(initiate<1{
throttleUp();
initiate = 1;
esc.detach();
1. expected unqualified id before numeric constant
2. expected , or ; before "int"
3. expected initializer before "if"
4. "esc" does not name a type
5. expected declaration before } token Thanks if you can help
That depends on the motor and what kind of performance and run time you expect.Do you think that this is okay for driving a DC motor in one direction with a 9 volt battery? thanks
In general, 9v batteries are a poor power source for motors. They have relatively low capacity and a very high internal resistance, so they drain quickly and do not perform well with high current loads.
C++ statements require a semicolon terminator. The semicolon is missing on several of these statements....but I still have errors...
int arm = 1000
int speedvalue;
int steady = 300
int initiate = 0
- masha
Dear Support, Can an esc and brushless motor in a quad copter kit be programmed to run off an arduino uno for autonomous not RC control without flashing the firmware on the esc?
@masha - Better to start a new thread for this question,
