Due to high demand expect some shipping delays at this time, orders may not ship for 3-4 business days. On MLK Day no orders will be shipped.
Disabling Clock Divide (CKDIV8) using USBtinyISP + AVRDude
by limaiem on Sat Feb 14, 2009 2:49 pm
I just assembled my USBtinyISP. I got he famous "rc=-1" error but I fixed the problem !
I succeeded in flashing my Attyny45 with AVRDude.
Now I am trying to disable the internal Fuse "CKDIV8" that divide the internal clock speed by 8 (I get 1MHz).
I do not what to disable the internal oscillator ! I just need to set CKDIV8 to off so I can get the internal speed to 8Mhz.
I tryed to use the Fuse Calculator Linked in the Ladyada USBtinyISP manual (ref, http://www.engbedded.com/cgi-bin/fc.cgi/) but the link is broken and I do not found any information for to do this.
Since it is a critical manipulation I am asking for Help here ...
Should I first read the all the Fuse statues before setting the new statues of should I just fix the fuse CKDIV8 to 0 !
The instruction will have this syntax ... :
avrdude -c usbtiny -p attiny45 -U hfuse:w:<0xHH>:m
someone can help ?
imed limaiem
(paris)
limaiem
Re: Disabling Clock Divide (CKDIV8) using USBtinyISP + AVRDude
by adafruit on Sat Feb 14, 2009 11:16 pm
either wait till the site goes up or go to avrfreaks.com or read the datasheet
by The_Don125 on Sun Feb 15, 2009 1:08 am
http://www.engbedded.com/cgi-bin/fc.cgi/ isn't working for you? I just tried it and its functioning for me...
Anyway, with the 8MHz internal oscillator active and a 64ms start-up time, no clock output on PORTB4, and no clock division, you actually want to set the low fuse, so your command should look more like:
avrdude -c usbtiny -p attiny45 -U lfuse:w:<0x62>:m
The_Don125
by magician13134 on Sun Feb 15, 2009 1:46 am
The_Don125 wrote:http://www.engbedded.com/cgi-bin/fc.cgi/ isn't working for you? I just tried it and its functioning for me...
I've tried that link maybe 5 times over the past few months and EVERY time gotten a "500 server error", but now it's working again. Wow...
magician13134
by limaiem on Sun Feb 22, 2009 5:59 pm
It worked for me last few days and I get the information I needed
The command line to use is:
avrdude -p attiny45 -c usbtiny -U lfuse:w:0xE2:m
All works fine !
Thank you for all,
ps:For those who had issues with "rc=-1" message, it could come from the board where the AVR ship is soldered (it could be write protected) the USBtinyISP is working really good and if all is soldered with even medium quality it should work fine
limaiem
by limaiem on Sun Feb 22, 2009 6:00 pm
Ok thank you
limaiem
by lyronold on Thu Nov 17, 2011 8:56 am
I've tried to do this with a arduino as programmer,
i used the command
avrdude -c Arduino -P COM7 -p attiny45 -U lfuse:w:<0x62>:m
but it responded with:
The system cannot find the file specified
How do i fix this?
lyronold
by mwilson on Thu Nov 17, 2011 11:19 am
Try
-U lfuse:w:0x62:m
man avrdude doesn't make any mention of those angle brackets.
mwilson
by lyronold on Thu Nov 17, 2011 11:28 am
aha that's doing something..
now i get the message:
avrdude: stk500_getsync(): not in sync: resp=0x00
lyronold
by mwilson on Thu Nov 17, 2011 12:06 pm
That's definitely something else. I don't know, but I googled "avrdude not_in_sync". The first hit wasn't worth much, but the second
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1248528012/all
might be helpful. And there are others.
mwilson
by lyronold on Thu Nov 17, 2011 12:47 pm
It is connected properly, i can upload code to the arduino itself, i can upload to the attiny but no avrdude :(
I am sure i used the right com port..
lyronold
