Raspberry Pi 3 WiFi not working out of the box
drake127
Post by drake127 »
I got my new Raspberry Pi 3 and WiFi has never worked on it. From the first boot until the last time I booted it, it has never been able to find my wireless network. I am running the latest version of Raspbian Jessie, updated and upgraded (I even tried rewriting the image to my SD card, twice). I have also tried a number of other things as suggested by forums on RaspberryPi.com and this website.
Is there anything else I could try or is the Pi likely defective?
Order number:1058545-0543046042 placed on March 24th
Thank you,
Devin
adafruit_support_mike
Re: Raspberry Pi 3 WiFi not working out of the box
What output do you get from `dmesg`?
drake127
Post by drake127 »
So I ran that command but......another issue has arisen that may or may not be related. So when I first got the Pi, I booted a couple of times before I went to set up the WiFi. That's when I noticed the issue with the WiFi. I updated and upgraded and when I rebooted following that, the Pi never came back to life. When I boot, the "startx" command appears to be run automatically as I have not yet changed the password. But this is what it never made it past. It would take me to a black screen with a flashing underscore cursor. After about 15 minutes stuck here, I punted and re-installed Raspbian Jessie onto my SD card. The Pi worked as normal after this and I was able to update, upgrade, and (successfully) reboot. After this, the WiFi still did not work and that's when I came to this forum. But this inability to boot happened again, so I am now on my third install of Raspbian. Anyways, here's what "dmesg" printed out:
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.1.19-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #858 SMP Tue Mar 15 15:56:00 GMT 2016
[    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: Raspberry Pi 3 Model B Rev 1.2
[    0.000000] cma: Reserved 8 MiB at 0x3a400000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 241664
[    0.000000] free_area_init_node: node 0, pgdat 80880fc0, node_mem_map b9bb4000
[    0.000000]   Normal zone: 2124 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 241664 pages, LIFO batch:31
[    0.000000] [bcm2709_smp_init_cpus] enter (9420->f3003010)
[    0.000000] [bcm2709_smp_init_cpus] ncores=4
[    0.000000] PERCPU: Embedded 12 pages/cpu @bafb0000 s20416 r8192 d20544 u49152
[    0.000000] pcpu-alloc: s20416 r8192 d20544 u49152 alloc=12*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 239540
[    0.000000] Kernel command line: 8250.nr_uarts=1 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2709.boardrev=0xa22082 bcm2709.serial=0xe7e796b2 smsc95xx.macaddr=B8:27:EB:E7:96:B2 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 939376K/966656K available (6064K kernel code, 534K rwdata, 1664K rodata, 444K init, 757K bss, 19088K reserved, 8192K cma-reserved)
[    0.000000] Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xbb800000 - 0xff000000   (1080 MB)
    lowmem  : 0x80000000 - 0xbb000000   ( 944 MB)
    modules : 0x7f000000 - 0x80000000   (  16 MB)
      .text : 0x80008000 - 0x807945f0   (7730 kB)
      .init : 0x80795000 - 0x80804000   ( 444 kB)
      .data : 0x80804000 - 0x80889b10   ( 535 kB)
       .bss : 0x8088c000 - 0x809497dc   ( 758 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000] Additional per-CPU info printed with stalls.
[    0.000000] NR_IRQS:608
[    0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000008] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.000025] Switching to timer-based delay loop, resolution 52ns
[    0.000242] Console: colour dummy device 80x30
[    0.001286] console [tty1] enabled
[    0.001339] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[    0.001408] pid_max: default: 32768 minimum: 301
[    0.001733] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001776] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002771] Initializing cgroup subsys blkio
[    0.002820] Initializing cgroup subsys memory
[    0.002867] Initializing cgroup subsys devices
[    0.002908] Initializing cgroup subsys freezer
[    0.002957] Initializing cgroup subsys net_cls
[    0.003031] CPU: Testing write buffer coherency: ok
[    0.003119] ftrace: allocating 20313 entries in 60 pages
[    0.048727] CPU0: update cpu_capacity 1024
[    0.048792] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.048827] [bcm2709_smp_prepare_cpus] enter
[    0.048986] Setting up static identity map for 0x8240 - 0x8274
[    0.050758] [bcm2709_boot_secondary] cpu:1 started (0) 17
[    0.050956] [bcm2709_secondary_init] enter cpu:1
[    0.050997] CPU1: update cpu_capacity 1024
[    0.051004] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.051391] [bcm2709_boot_secondary] cpu:2 started (0) 17
[    0.051556] [bcm2709_secondary_init] enter cpu:2
[    0.051578] CPU2: update cpu_capacity 1024
[    0.051584] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.051948] [bcm2709_boot_secondary] cpu:3 started (0) 18
[    0.052079] [bcm2709_secondary_init] enter cpu:3
[    0.052099] CPU3: update cpu_capacity 1024
[    0.052105] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.052168] Brought up 4 CPUs
[    0.052266] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[    0.052296] CPU: All CPU(s) started in HYP mode.
[    0.052322] CPU: Virtualization extensions available.
[    0.053024] devtmpfs: initialized
[    0.071734] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[    0.072014] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.072865] pinctrl core: initialized pinctrl subsystem
[    0.073418] NET: Registered protocol family 16
[    0.078542] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[    0.079521] bcm2709.uart_clock = 48000000
[    0.083600] bcm2709: Mini UART enabled
[    0.083668] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.083714] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.083888] Serial: AMBA PL011 UART driver
[    0.083952] uart-pl011 3f201000.uart: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[    0.084149] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[    0.149462] bcm2708-dmaengine 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0xf35
[    0.149533] bcm2708-dmaengine 3f007000.dma: Initialized 7 DMA channels (+ 1 legacy)
[    0.150125] bcm2708-dmaengine 3f007000.dma: Load BCM2835 DMA engine driver
[    0.150162] bcm2708-dmaengine 3f007000.dma: dma_debug:0
[    0.150733] SCSI subsystem initialized
[    0.150942] usbcore: registered new interface driver usbfs
[    0.151056] usbcore: registered new interface driver hub
[    0.151176] usbcore: registered new device driver usb
[    0.151720] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-03-15 14:47
[    0.178816] Switched to clocksource arch_sys_counter
[    0.220251] FS-Cache: Loaded
[    0.220542] CacheFiles: Loaded
[    0.229897] NET: Registered protocol family 2
[    0.230864] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.231004] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.231215] TCP: Hash tables configured (established 8192 bind 8192)
[    0.231329] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.231397] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.231725] NET: Registered protocol family 1
[    0.232050] RPC: Registered named UNIX socket transport module.
[    0.232082] RPC: Registered udp transport module.
[    0.232110] RPC: Registered tcp transport module.
[    0.232137] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.233094] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[    0.234170] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.247546] VFS: Disk quotas dquot_6.6.0
[    0.247878] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.250006] FS-Cache: Netfs 'nfs' registered for caching
[    0.250927] NFS: Registering the id_resolver key type
[    0.250989] Key type id_resolver registered
[    0.251017] Key type id_legacy registered
[    0.253095] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    0.253272] io scheduler noop registered
[    0.253311] io scheduler deadline registered (default)
[    0.253601] io scheduler cfq registered
[    0.255876] BCM2708FB: allocated DMA memory fa800000
[    0.255923] BCM2708FB: allocated DMA channel 0 @ f3007000
[    0.282466] Console: switching to colour frame buffer device 228x61
[    0.297902] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
[    0.299517] console [ttyS0] disabled
[    0.299636] 3f215040.uart: ttyS0 at MMIO 0x3f215040 (irq = 29, base_baud = 50000000) is a 16550
[    1.496521] console [ttyS0] enabled
[    1.503172] vc-cma: Videocore CMA driver
[    1.509629] vc-cma: vc_cma_base      = 0x00000000
[    1.517326] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
[    1.526177] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    1.535180] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[    1.560087] brd: module loaded
[    1.572067] loop: module loaded
[    1.578035] vchiq: vchiq_init_state: slot_zero = 0xba880000, is_master = 0
[    1.590905] Loading iSCSI transport class v2.0-870.
[    1.599584] usbcore: registered new interface driver smsc95xx
[    1.609044] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.818734] Core Release: 2.80a
[    1.823914] Setting default values for core params
[    1.831795] Finished setting default values for core params
[    2.041269] Using Buffer DMA mode
[    2.046693] Periodic Transfer Interrupt Enhancement - disabled
[    2.056254] Multiprocessor Interrupt Enhancement - disabled
[    2.065388] OTG VER PARAM: 0, OTG VER FLAG: 0
[    2.072554] Dedicated Tx FIFOs mode
[    2.078592] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xba814000 dma = 0xfa814000 len=9024
[    2.094720] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
[    2.134564] dwc_otg: Microframe scheduler enabled
[    2.134614] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x80417288
[    2.148446] WARN::hcd_init_fiq:413: FIQ ASM at 0x804175f8 length 36
[    2.162820] WARN::hcd_init_fiq:438: MPHI regs_base at 0xbb89c000
[    2.176788] dwc_otg 3f980000.usb: DWC OTG Controller
[    2.189047] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[    2.205143] dwc_otg 3f980000.usb: irq 32, io mem 0x00000000
[    2.218401] Init: Port Power? op_state=1
[    2.228920] Init: Power Port (0)
[    2.238479] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    2.253760] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.269754] usb usb1: Product: DWC OTG Controller
[    2.281616] usb usb1: Manufacturer: Linux 4.1.19-v7+ dwc_otg_hcd
[    2.295566] usb usb1: SerialNumber: 3f980000.usb
[    2.307865] hub 1-0:1.0: USB hub found
[    2.318120] hub 1-0:1.0: 1 port detected
[    2.328953] dwc_otg: FIQ enabled
[    2.328962] dwc_otg: NAK holdoff enabled
[    2.328970] dwc_otg: FIQ split-transaction FSM enabled
[    2.329003] Module dwc_common_port init
[    2.329273] usbcore: registered new interface driver usb-storage
[    2.343312] mousedev: PS/2 mouse device common for all mice
[    2.357121] bcm2835-cpufreq: min=600000 max=1200000
[    2.369435] sdhci: Secure Digital Host Controller Interface driver
[    2.383623] sdhci: Copyright(c) Pierre Ossman
[    2.395087] sdhost: log_buf @ ba813000 (fa813000)
[    2.478850] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    2.514266] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[    2.518922] Indeed it is in host mode hprt0 = 00021501
[    2.540342] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[    2.588932] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.601980] mmc0: host does not support reading read-only switch, assuming write-enable
[    2.606181] mmc0: new high speed SDHC card at address aaaa
[    2.606658] mmcblk0: mmc0:aaaa SS08G 7.40 GiB
[    2.608067]  mmcblk0: p1 p2
[    2.653045] ledtrig-cpu: registered to indicate activity on CPUs
[    2.667040] hidraw: raw HID events driver (C) Jiri Kosina
[    2.680124] usbcore: registered new interface driver usbhid
[    2.693314] usbhid: USB HID core driver
[    2.696687] mmc1: queuing unknown CIS tuple 0x41 (244 bytes)
[    2.708853] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.708979] Indeed it is in host mode hprt0 = 00001101
[    2.737064] mmc1: queuing unknown CIS tuple 0x80 (128 bytes)
[    2.758070] Initializing XFRM netlink socket
[    2.769208] NET: Registered protocol family 17
[    2.777678] mmc1: queuing unknown CIS tuple 0x80 (128 bytes)
[    2.794028] Key type dns_resolver registered
[    2.805529] Registering SWP/SWPB emulation handler
[    2.818096] registered taskstats version 1
[    2.829195] vc-sm: Videocore shared memory driver
[    2.841006] [vc_sm_connected_init]: start
[    2.852155] [vc_sm_connected_init]: end - returning 0
[    2.865878] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
[    2.902013] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.919658] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    2.919730] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[    2.919742] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.950283] hub 1-1:1.0: USB hub found
[    2.976100] hub 1-1:1.0: 5 ports detected
[    2.977168] devtmpfs: mounted
[    2.977962] Freeing unused kernel memory: 444K (80795000 - 80804000)
[    3.288870] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    3.297807] random: systemd urandom read with 93 bits of entropy available
[    3.322721] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -BANNED)
[    3.349232] systemd[1]: Detected architecture 'arm'.
[    3.419140] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    3.434817] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.453885] smsc95xx v1.0.4
[    3.522652] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:e7:96:b2
[    3.534245] NET: Registered protocol family 10
[    3.535647] systemd[1]: Inserted module 'ipv6'
[    3.538983] systemd[1]: Set hostname to <raspberrypi>.
[    3.852494] random: nonblocking pool is initialized
[    3.989642] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[    4.007217] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    4.024232] systemd[1]: Expecting device dev-ttyS0.device...
[    4.043596] systemd[1]: Starting Remote File Systems (Pre).
[    4.062805] systemd[1]: Reached target Remote File Systems (Pre).
[    4.077458] systemd[1]: Starting Encrypted Volumes.
[    4.095474] systemd[1]: Reached target Encrypted Volumes.
[    4.109065] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[    4.133872] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    4.154004] systemd[1]: Starting Swap.
[    4.170444] systemd[1]: Reached target Swap.
[    4.182194] systemd[1]: Expecting device dev-mmcblk0p1.device...
[    4.202279] systemd[1]: Starting Root Slice.
[    4.219579] systemd[1]: Created slice Root Slice.
[    4.232009] systemd[1]: Starting User and Session Slice.
[    4.251071] systemd[1]: Created slice User and Session Slice.
[    4.265212] systemd[1]: Starting Delayed Shutdown Socket.
[    4.284378] systemd[1]: Listening on Delayed Shutdown Socket.
[    4.298535] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[    4.319836] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    4.336075] systemd[1]: Starting Journal Socket (/dev/log).
[    4.355785] systemd[1]: Listening on Journal Socket (/dev/log).
[    4.370320] systemd[1]: Starting udev Control Socket.
[    4.388986] systemd[1]: Listening on udev Control Socket.
[    4.402624] systemd[1]: Starting udev Kernel Socket.
[    4.421106] systemd[1]: Listening on udev Kernel Socket.
[    4.434651] systemd[1]: Starting Journal Socket.
[    4.452659] systemd[1]: Listening on Journal Socket.
[    4.465643] systemd[1]: Starting System Slice.
[    4.483046] systemd[1]: Created slice System Slice.
[    4.495640] systemd[1]: Starting File System Check on Root Device...
[    4.518242] systemd[1]: Starting system-systemd\x2dfsck.slice.
[    4.538533] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    4.553855] systemd[1]: Starting system-autologin.slice.
[    4.572780] systemd[1]: Created slice system-autologin.slice.
[    4.586693] systemd[1]: Starting system-serial\x2dgetty.slice.
[    4.606260] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    4.621157] systemd[1]: Starting Increase datagram queue length...
[    4.643809] systemd[1]: Starting Restore / save the current clock...
[    4.674066] systemd[1]: Mounted Huge Pages File System.
[    4.708671] systemd[1]: Starting Load Kernel Modules...
[    4.729632] systemd[1]: Mounting POSIX Message Queue File System...
[    4.762045] systemd[1]: Started Set Up Additional Binary Formats.
[    4.780114] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    4.795043] fuse init (API version 7.23)
[    4.805184] i2c /dev entries driver
[    4.830516] systemd[1]: Mounting Debug File System...
[    4.851745] systemd[1]: Starting udev Coldplug all Devices...
[    4.874016] systemd[1]: Starting Slices.
[    4.890776] systemd[1]: Reached target Slices.
[    4.910137] systemd[1]: Mounted Debug File System.
[    4.928053] systemd[1]: Mounted POSIX Message Queue File System.
[    4.948791] systemd[1]: Started File System Check on Root Device.
[    4.980444] systemd[1]: Started Increase datagram queue length.
[    5.001081] systemd[1]: Started Restore / save the current clock.
[    5.021951] systemd[1]: Started Load Kernel Modules.
[    5.041662] systemd[1]: Started Create list of required static device nodes for the current kernel.
[    5.068691] systemd[1]: Time has been changed
[    5.121517] systemd[1]: Started udev Coldplug all Devices.
[    5.245935] systemd[1]: Starting Create Static Device Nodes in /dev...
[    5.269904] systemd[1]: Mounting Configuration File System...
[    5.292197] systemd[1]: Starting Apply Kernel Variables...
[    5.314610] systemd[1]: Mounting FUSE Control File System...
[    5.336890] systemd[1]: Starting Syslog Socket.
[    5.355970] systemd[1]: Listening on Syslog Socket.
[    5.356120] systemd[1]: Starting Journal Service...
[    5.370137] systemd[1]: Started Journal Service.
[    5.500811] systemd-udevd[109]: starting version 215
[    5.986227] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[    6.839512] bcm2835-rng 3f104000.rng: hwrng registered
[    7.798860] usb 1-1.5: new low-speed USB device number 4 using dwc_otg
[    7.910461] usb 1-1.5: New USB device found, idVendor=046d, idProduct=c016
[    7.910484] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    7.910498] usb 1-1.5: Product: Optical USB Mouse
[    7.910510] usb 1-1.5: Manufacturer: Logitech
[    7.916842] input: Logitech Optical USB Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/0003:046D:C016.0001/input/input0
[    7.917322] hid-generic 0003:046D:C016.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech Optical USB Mouse] on usb-3f980000.usb-1.5/input0
[   11.405580] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   11.716917] systemd-journald[108]: Received request to flush runtime journal from PID 1
[   14.901896] uart-pl011 3f201000.uart: no DMA platform data
[   15.053780] cfg80211: Calling CRDA to update world regulatory domain
[   18.208871] cfg80211: Calling CRDA to update world regulatory domain
[   21.360983] cfg80211: World regulatory domain updated:
[   21.360998] cfg80211:  DFS Master region: unset
[   21.361003] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[   21.361011] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   21.361018] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   21.361024] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[   21.361031] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[   21.361039] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[   21.361045] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[   21.361051] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[   21.361057] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[   21.628831] usb 1-1.4: new low-speed USB device number 5 using dwc_otg
[   21.913668] usb 1-1.4: New USB device found, idVendor=03f0, idProduct=034a
[   21.913678] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   21.913684] usb 1-1.4: Product: HP Elite USB Keyboard
[   21.913691] usb 1-1.4: Manufacturer: Chicony
[   21.983128] input: Chicony HP Elite USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:03F0:034A.0002/input/input1
[   22.039058] hid-generic 0003:03F0:034A.0002: input,hidraw1: USB HID v1.10 Keyboard [Chicony HP Elite USB Keyboard] on usb-3f980000.usb-1.4/input0
[   22.101568] input: Chicony HP Elite USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:03F0:034A.0003/input/input2
[   22.159078] hid-generic 0003:03F0:034A.0003: input,hidraw2: USB HID v1.10 Device [Chicony HP Elite USB Keyboard] on usb-3f980000.usb-1.4/input1
[   23.051306] Bluetooth: Core ver 2.20
[   23.051357] NET: Registered protocol family 31
[   23.051362] Bluetooth: HCI device and connection manager initialized
[   23.051377] Bluetooth: HCI socket layer initialized
[   23.051388] Bluetooth: L2CAP socket layer initialized
[   23.051412] Bluetooth: SCO socket layer initialized
[   24.718627] Bluetooth: HCI UART driver ver 2.3
[   24.718644] Bluetooth: HCI UART protocol H4 registered
[   24.718649] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   24.718655] Bluetooth: HCI UART protocol BCM registered
[   38.493892] Adding 102396k swap on /var/swap.  Priority:-1 extents:3 across:1773568k SSFS
[   39.458465] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   39.458479] Bluetooth: BNEP filters: protocol multicast
[   39.458495] Bluetooth: BNEP socket layer initialized
[   39.730189] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[   39.730339] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   41.235198] mmc1: error -22 whilst initialising SDIO card
[   41.386548] mmc1: queuing unknown CIS tuple 0x41 (244 bytes)
[   41.437968] mmc1: queuing unknown CIS tuple 0x80 (128 bytes)
[   41.490067] mmc1: queuing unknown CIS tuple 0x80 (128 bytes)
Last edited by adafruit_support_mike on Fri Apr 15, 2016 11:17 pm, edited 1 time in total.
Reason: added CODE tags
DoctorLar
Post by DoctorLar »
In case you haven't gotten anywhere, I had many frustrating days with Pi3 and Jessie. Out of the box I could not get update/upgrades to connect. I finally figured out that my issue was that I could connect to the LAN, but nothing outside the network. There is a problem with Pi3 Jessie and a few routers, everything comes through from the DH CP EXCEPT the default gateway. gggrrrrrrr SO, each time I load up I run this in command: sudo route add default gw 192.168.1.1
Hoping a better fix comes along or that it at least gets you working.
drake127
Post by drake127 »
Alright, yeah thanks! I will definitely give it a try.
Return to “Microcontrollers”
