Unable to upload to Feather Bluefruit LE
by jasper421 on Sun May 08, 2016 3:06 pm
I recently purchased a Feather BLE intended for use in a quadcopter, due to its small size and many features.
Upon connecting it to my laptop (MacBook Pro 13 inch, mid 2012, El Capitan) the red LED (#13) pulses continuously. It shows up in the IDE as /dev/cu.usbmodem1411 but I am unable to upload any code to it. According to the product description, it should enumerate as "Adafruit Feather 32u4".
I have "Adafruit Feather 32u4" selected in the boards menu, on the Arduino IDE 1.6.8. When the reset button on the board is depressed, the the LED stops pulsing, however as soon as the button is released, it continues pulsing. It does not matter if the button is pressed once or twice (to enter bootloader), it only pulses. Even if the board is connected to a battery (no USB connection), I get the same results.
The basic "blink" sketch compiles fine, however it fails to finish uploading. The verbose output reads as follows:
         Using Port                    : /dev/cu.usbmodem1411
         Using Programmer              : avr109
         Overriding Baud Rate          : 57600
         AVR Part                      : ATmega32U4
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : butterfly
         Description     : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
I have been unable to upload any sketches to the board, however I can connect to the nRF51822 with the Flora BLE app. Additionally, I have tried to upload on another mac and with another USB cable and had the same results. I have also tried this fix, to no avail: https://learn.adafruit.com/adafruit-feather-32u4-adalogger/faq
Any ideas as to what the issue is? Hardware? Is the board fried?
Thank you in advance!
jasper421
Re: Unable to upload to Feather Bluefruit LE
by adafruit_support_mike on Mon May 09, 2016 2:58 am
The red LED should pulse for about 10 seconds after you release the reset button. Does it keep pulsing longer than that?
by jasper421 on Mon May 09, 2016 9:11 am
The LED pulses forever, without stopping. I've tried leaving for more than a half an hour and it continues to pulse.
jasper421
by adafruit_support_mike on Tue May 10, 2016 4:10 am
Hmm.. do you have anything connected to it besides the USB cable?
by jasper421 on Tue May 10, 2016 7:21 am
Nothing at all, the board is brand new and has not been used with anything else except the battery, which yields the same results.
jasper421
by adafruit_support_mike on Tue May 10, 2016 11:05 pm
That's wierd, but let's see if anything is obviously amiss with the hardware.
Post a photo showing the component side of the Feather please, well enough lit and focused that we can see all the parts. 800x600 images usually work best.
by jasper421 on Wed May 11, 2016 8:37 am
All components appear to look fine, no cold joints or visible parts missing as far as I can tell.
jasper421
by adafruit_support_mike on Thu May 12, 2016 4:15 am
Aha! You don't have a 32u4.. you have an M0.
Try selecting "Adafruit Feather M0" in the Tools->Board menu and see if that makes it behave.
by nishu0f0 on Mon May 14, 2018 9:00 am
Picture of my Feather 32U4 Bluefruit LE
I am facing the same issue. I ame using Feather 32u4 Bluefruit LE. Attached photo
nishu0f0
by nishu0f0 on Tue May 15, 2018 5:33 am
Update** : Fixed this issue by applying adafruit's custom udev rules to my ubuntu pc.
nishu0f0
by ssfaizan2 on Thu Nov 29, 2018 3:59 am
Hey,
I am facing the similar issue with my Feather Adalogger M0 board, and all the new boards also goes into the same mode where it shows 'programer not responding'. Can you please advise how did you fix it?
Sohail
ssfaizan2
by adafruit_support_mike on Thu Nov 29, 2018 4:20 am
First, verify your USB cable by using it to connect some other, known-working device to the computer.
There's a plague of charge-only cables out there with USB connectors at both ends, but no wires for the data signals. We see people get caught by them every day, and it's become normal for people to say they had to try three or four cables before finding one that worked.
by ssfaizan2 on Thu Nov 29, 2018 4:40 am
Yes, I did change three different cables. I am using the cables that come with other development kit for prgramming. It doesn't work for any of the cables now.
ssfaizan2
by adafruit_support_mike on Fri Nov 30, 2018 1:06 am
Sorry, I need a specific set of words: does any cable you tried sucessfully connect another, known-working device to the computer? I need a positive test before I can rule out a false negative.
by ssfaizan2 on Fri Nov 30, 2018 1:18 am
I started with one device and a specific cable. It worked absolutely fine for about 10-15 different programs and I tried multiple codes on the same device using same cable.
Then I tried to use a delay mode for checking power savings and then kt started not responding.
I switched to new device and it didn't work for simple blink LED example as well.
Then I ran through the steps provided, changed cable, opened verbose and pressing the reset twice during upload. However, it worked for only one device and not for the 3 new devices.
Now all the devices show programmer not responding regardless of which PC I use, which cable I use and even if I start fresh with a new board.
I hope this is enough details that was needed.
ssfaizan2
